The Game Feels Sluggish, Enemies Are Too Fast, and You Die in a Millisecond
rusihhh
Re: The Game Feels Sluggish, Enemies Are Too Fast, and You Die in a Millisecond
@themagic
I really appreciate your position — and I fully agree that ISP quality, routing or even hardware choices have limited impact on this theory.
Yes, they can matter a bit — but what we’re discussing here seems deeper, likely engine-level behavior or netcode logic.
Respect to you for trying to help, staying on-topic, and thinking critically.
Please don’t let yourself be baited by users like @1000WATT — he’s just throwing sarcasm and shouting “skill issue” while showing no understanding of what’s being analyzed here.
Honestly, I doubt he even knows the basics like OSI or TCP/IP.
I’m not trying to win arguments. I’m trying to explore a **technical theory** that may help others too.
Compared to hunting for “magic” power sockets or golden PC configurations, this approach feels more grounded.
1. We’ve all seen low-end setups dominate high-end players — so clearly hardware isn’t the only factor.
2. Even on the same PC, game feeling can change drastically between servers.
3. Which suggests something external is shaping gameplay — possibly packet-level differences or update behavior.
Thanks again for being one of the few staying respectful and constructive here.
@1000WATT
You really don’t want to know who I am — but let me be clear:
Your behavior in this thread has been nothing short of disgraceful.
You’ve made cringe jokes about “hormones,” insulted people’s skills, and contributed exactly zero technical insight.
“Skill issue”?
I’m a top-rank player in Rainbow Six Siege — and I’m not whining about losing every game.
I’m asking why, in back-to-back matches against the same players, but on different servers, the gameplay feels like two completely different games.
In one I’m unstoppable. In the next, I can’t even react before being deleted.
And here’s my personal take on you:
- You make irrelevant and inappropriate jokes
- You’re not contributing technically
- You likely don’t understand even basic networking
- And worst of all — you mock others while offering nothing
Meanwhile, I’m reading every message in this thread and treating everyone with respect — including you.
But you’ve repeatedly derailed a serious topic, and frankly, it’s getting old.
To others who are reading or thinking about this theory:
Some people here mentioned changes in resolution or capped framerates affecting the feel of the game.
Interestingly — when I spoke to some developer friends — they noted that rendering load can influence netcode behavior.
If there are fewer objects or animations per frame, it’s possible the game sends fewer updates — or receives less.
Also, high FPS might trigger more frequent client ticks — leading to different sync timing.
I may be wrong on this, but it’s worth exploring.
If you’ve seen the same patterns — or know more about Source 2/CS2 netcode — I’d love to hear it.
Let’s stay curious and collaborative.
@1000WATT
“Skill issue”?
1000WATT
Well, if you are such a sociable guy, answer the question from this post.rusihhh wrote: Meanwhile, I’m reading every message in this thread and treating everyone with respect — including you.
viewtopic.php?f=10&t=14790&start=60#p117203
rusihhh
Yes, I read it — and I can easily answer:1000WATT wrote: ↑03 Jul 2025, 10:20Well, if you are such a sociable guy, answer the question from this post.rusihhh wrote: Meanwhile, I’m reading every message in this thread and treating everyone with respect — including you.
We're not looking for small spikes in packet size.
What I'm measuring is the **average packet size**, which is much more telling, since the average is clearly shifted.
Please check my **very first post** in this thread:
I showed graphs where the average incoming packet size is already visibly shifted.
This is strictly about **incoming packets**.
In both sessions, the **packet count per second** was absolutely stable — a flat line.
But the **packet sizes** fluctuated heavily, and their average shifted across matches.
As for your point: yes, obviously, what happens on screen affects packet size.
But that alone isn’t enough to **consistently shift the average** over the full session.
1000WATT
I disagree, let's say in 1 match you have most of the players using the StarCraft playstyle with APM ~ 1000. In another match you have most of the players using the PUBG playstyle, sitting in the toilet with APM ~ 10.rusihhh wrote: As for your point: yes, obviously, what happens on screen affects packet size.
You have not contacted the forum members to find a suitable method to confirm your theory.rusihhh wrote: - You’re not contributing technically
If you had written: guys, let's come up with conditions and methods to use, listen to criticism, agree and approve. Having considered all the options, let's start collecting and analyzing data. Then my communication with you would have been completely different.
rusihhh
And once again, you're nitpicking wording instead of engaging with the actual technical content. Should I just say “maybe Mars was in the wrong phase and that’s why my game felt off”? Sounds like that might interest you more.1000WATT wrote: You have not contacted the forum members to find a suitable method to confirm your theory.
Why are you even bringing up who I contacted or not? Unfortunately, I ended up having this discussion with you, when I was hoping to talk to someone genuinely interested in the subject. From all your replies so far, your only message has been: “this theory is garbage” — without offering a single technical rebuttal.
Zero technical counterpoints. Just semantic complaints, jokes about “server hormones,” and ignoring the charts and data.
About your “take” on my claim: I’m clearly talking about **FPS games** with fixed player counts, synchronized rounds, and steady gameplay tempo. You respond with comparisons to 100-player battle royales with players AFK in toilets? Come on.
Let me state this openly and clearly:
**RAINBOW SIX SIEGE sends different average packet sizes from the server to different players in the same match.**
Not spikes. Not anomalies. I’m talking about consistent average ranges.
Does the client react differently depending on what it receives? I strongly believe so.
How does the game determine this behavior? Unknown. Ping might be *one* factor, but it’s not the only one.
I also believe the same pattern exists in **CS2** and **Valorant**.
Your response? "Nope, that's not it" + a hormone joke + an irrelevant example.
You’ve ignored the graphs, ignored the opening post, and now act like the discussion was never technical to begin with.
And just out of curiosity — with a nickname like “WATT” — are you one of those guys chasing “golden power sockets” or the perfect PC build using parts from a single factory batch under a full moon?
(Sorry for the sarcasm, couldn’t resist.)
Let’s just end this with clarity:
**Your stance is that the theory is trash. Just trash. No reasoning needed.**
Got it.
1000WATT
You have already written enough unflattering things about me, presenting me in a negative light.
Please show me my messages in which I claimed that your theory is garbage.
Hyote
I have to add that power plans also make a huge difference. Mine is the best of course.
rusihhh
You're absolutely right — I want to apologize if my words portrayed you in a negative light. That wasn’t my intention.1000WATT wrote: Please show me my messages in which I claimed that your theory is garbage.
What triggered my tone was a mix of your earlier remarks — particularly the one about “skill issues” of other players and the jokes about “server hormones.” These made it feel like my points weren’t being taken seriously. I reacted emotionally — and I own that.
But if I may clarify: when I said “your stance is that the theory is trash,” I was speaking figuratively, based on how each of your replies consistently tried to refute the idea — sometimes sarcastically, sometimes dismissively.
I didn’t mean you literally typed “theory = trash,” but that’s how the tone came across from my side.
That said — I *do* want a real discussion here.
If you’re open to it, I’d sincerely appreciate hearing your **technical perspective**:
- How do you interpret the theory?
- What parts of it do you agree or disagree with — and why?
- What’s your final stance, and are there any questions you’d raise about the claim?
Maybe I’m explaining it poorly — so I’d also be happy to clarify the theory in simpler or more precise terms if needed.
rusihhh
Is this an ad?Hyote wrote: I have to add that power plans also make a huge difference. Mine is the best of course.
Like — *“DM me for the ultimate PC power plan, only $19.99, guaranteed to unlock your hidden FPS”*?
But jokes aside — just to clarify — this topic is primarily about **network behavior and packet handling**, not general PC performance.
Sure, it’s great you’re offering a config that helps overall system responsiveness — but as I wrote earlier:
“Better settings → better performance” is kinda obvious, no?
Update your PC — it works better.
Tweak power plans — it runs smoother.
That’s baseline.
Hyote
Yeah dude, dm me for a secret power plan, totally not the one that's on GitHub, since there are only 3 links below my posts.rusihhh wrote: ↑03 Jul 2025, 11:57Is this an ad?Hyote wrote: I have to add that power plans also make a huge difference. Mine is the best of course.
That’s baseline.
The only reason I butted in with such a reply is because there are still some people left who give the same bullshit answer to every question, create conflict and then this cycle goes on. They really have nothing to present other than their "big company manipulates my every step" argument in this case.
