No FPS gaming possible
Re: No FPS gaming possible
Post by Slender » 02 Aug 2025, 12:58
for many test and logic, /set no mean /deletevalue
if you feel different tell me
LaggyTyp
Post by LaggyTyp » 02 Aug 2025, 16:48
My Settings:
Code: Select all
1.) All network card options (Device Manager) disabled
a) Interrupt Moderation = On
b) Interrupt Moderation Rate = Off
d) Network card Transmit Buffer (Device Manager) = 1024
e) Network card Receive Buffer (Device Manager) = 2048
2.) REG: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Multimedia\SystemProfile
a) NetworkThrottlingIndex = 70 (Decimal)
b) SystemResponsiveness = 0 (Decimal)
3.) CMD@Admin: netsh interface tcp set global rsc=disabled
4.) CMD@Admin: netsh interface udo set global uro=disabled
5.) CMD@Admin: netsh interface udo set global uso=disabled
6.) CMD@Admin: bcdedit /set tscsyncpolicy enhanced
7.) CMD@Admin: bcdedit /set useplatformclock no
8.) CMD@Admin: bcdedit /set disabledynamictick yes
9.) Device-Manager: HPET = Disabled
10.) netsh interface tcp set global autotuninglevel=highlyrestricted
The hit reg is wonderful with it!
BUT: Everyone sees me way too fast! I'm running toward a corridor, there are smokes everywhere, I jump around the corner while running, aim down, and the enemy has me in his crosshairs for a long time. It's as if I had already jumped around the corner on the server. WTF?
Dcyker
Post by Dcyker » 02 Aug 2025, 16:58
It's the same for me in Valorant, people always have an advantage no matter their Ping, they always see me first. I can crouch/jump it doesn't matter they kill me instantly.
LaggyTyp
Post by LaggyTyp » 02 Aug 2025, 19:55
bcdedit /set disabledynamictick yes + NetworkThrottlingIndex = 70 = Good
bcdedit /set disabledynamictick yes + NetworkThrottlingIndex = ffffffff = Horror
bcdedit /set disabledynamictick no + NetworkThrottlingIndex = ffffffff = Good
BUT WHY?
Post by Slender » 03 Aug 2025, 01:41
LaggyTyp wrote: ↑
02 Aug 2025, 19:55
BUT WHY?
try hard disable mmcss service (it include index and sysresp)
LaggyTyp
Post by LaggyTyp » 03 Aug 2025, 04:22
I can't find the service under Services?
Post by Slender » 03 Aug 2025, 07:36
LaggyTyp wrote: ↑
03 Aug 2025, 04:22
sc config MMCSS start=auto
sc start MMCSS
sc config MMCSS start=disabled
sc stop MMCSS
LaggyTyp
Post by LaggyTyp » 04 Aug 2025, 02:01
bcdedit /set useplatformtick yes
When I run this command, my ping drops from ~14 ms to 5-6 ms but the hitreg is then completely broken.
Post by Slender » 04 Aug 2025, 05:25
LaggyTyp wrote: ↑
04 Aug 2025, 02:01
touch that only in w11 if you disable hpet timer in bios.
you can open dpc latency cheker 1.4.0 and compare it.
LaggyTyp
Post by LaggyTyp » 04 Aug 2025, 06:31
There's no HPET option in my BIOS. Wouldn't it be sufficient to disable HPET in Device Manager?
Are there any other commands that should be set for this option (combination)?
