DMA cheater cards and everything gonna be nothing agains this...
No FPS gaming possible
- themagic
Re: No FPS gaming possible
The only thing where AI will be really useful is cheating...soon there will be "who can made the better AI cheat"...
drosku
in riot repair tool they used to have sync system timer lol thats intresting
skillissues999
After using these netsh commands, for 2 days I was just flying around the maps and the opponents were reacting to me ultra-slowly. It felt like I could see, drink a cup of coffee, scratch my balls, and then press the right mouse button. But unfortunately, the effect of these commands disappeared. Why is that? Is it oversaturation or what?
LaggyTyp
The problem is my internet provider.
https://www.cablelabs.com/blog/how-docs ... gement/amp
The line belongs to Vodafone. So no matter where I switch, it always stays on Vodafone's infrastructure. The same applies to VDSL. It's always Telekom's infrastructure. Even if they connect me to fiber, the problem will still exist. I suspect they also use devices that bundle packets and then cause this delay.
I'm currently watching a video by Ekwah (Warzone and Battlefield YouTuber). In all of his rounds, his opponents react 100% differently than they do to me. It's like he's playing against complete idiots. Everyone in my game is so focused that it's almost frustrating. He must have a line that just works well. Because he doesn't play so exceptionally well that it would make a huge difference to me. I can't move like him in the game without being shot at by 20 people.
It's this delay despite low ping. Network cards have this function to buffer and bundle packets. I've disabled everything that made it better, but there's still something there. Probably the ISP.
There's no solution for me.
Perhaps a GigaCube from Vodafone with unlimited 5G?
MontyTheAverage
you have to try at different location first to base it down to internet. Or even gaming with mobile hotspot/usb thethering if you got good hotspot. I have tried and it occurs other locations with other internet connections also.LaggyTyp wrote: ↑18 Aug 2025, 19:48The problem is my internet provider.
LaggyTyp
My mobile internet isn't very good (prepaid), but I've played a good round with it. The only problem was that the ping sometimes went up to 999ms.
MontyTheAverage
You would need to play more than 1 match since usually when you switch to a new Internet connection, the problem can improve for few minutes or 1 match.
Also ping spikes weirdly helps this problem. It can switch between good and bad states before it after spikes. At least for me.
Btw, do you play BF2042? If so, turn on damage log. It should show how much damage each bullets do and also shows something called deltatick. Check if the numbers vary a lot. For example, one bullet having low number between 1 to 10, another bullet have high numbers between 20 to 99+. I'm not fully sure but I think this shows the desync(dying so fast) in data and real time with the inconsistent deltatick.
LaggyTyp
Yes, I play BF2042 and soon Battlefield 6.
I die in record time. It's like 10 shots are coming at once. I have no chance to react. My shots do no damage. Just imagine a game against cheaters, and you're the only ones not cheating.
To put it in one sentence: It's like I'm in the past and not live.
MontyTheAverage
Yea same. I joined a match and I was 7-0 when I joined with enemies dying easy and fast. Ended the match with 24-26 negative lmao. After the first 2 minute of proper gameplay, it goes to shit. Enemies go from looking like boys to everyone playing like esports pros and dying instantly.LaggyTyp wrote: ↑19 Aug 2025, 06:36Yes, I play BF2042 and soon Battlefield 6.
Also I'm wrong, if the numbers are small, then it's bad for the deltatick on the damage log. So it shows the frames passed since previous damage event. I have a lot of 0-10 numbers on deaths for it. That shows how fast we are dying.
LaggyTyp
I wouldn't complain if it were like that for everyone, but it isn't. Friends from my area don't have any problems. Friends from other countries don't have any problems. Just me.
In the BF6 beta, I saw run-of-the-mill noobs come around the corner shooting. No, not pre-fire! It looked like pre-fire, but it wasn't. I was probably just standing there on their screen, even though I play aggressively and always push.
This topic is giving me gray hair. I'm slowly losing my will and ability to deal with it.
