RTX 3070 Driver recommendation
crack
Post by crack » 02 Sep 2025, 23:01
Currently using 566.14, MSI enabled, undefined priority, machinedefault (I get random stutters if I change from default). Pretty much exclusively play games released before 2020, is it worth installing an older driver than this one?
Re: RTX 3070 Driver recommendation
Post by Slender » 03 Sep 2025, 11:11
crack wrote:
02 Sep 2025, 23:01
i have BIG frametime spikes and games just freeze on these 566.36 and 566.14
try 566.03
crack
Post by crack » 03 Sep 2025, 17:44
It feels better than 566.14, personally I didn't have frametime spikes or freezes because of the 566.14 driver, not once :D. I installed 566.14 and 566.03 with NVSlimmer. 1 min 1 second latency mon screenshots:
crack
Post by crack » 03 Sep 2025, 18:36
kyube
Post by kyube » 04 Sep 2025, 09:00
crack wrote:
03 Sep 2025, 18:36
Your test data only covers 1 scenario: idle on desktop, which isn't representative of what you feel in-game.
The DPC/ISR performance values significantly change once you introduce D3D9-12 3d workloads (games) or OpenGL/VK 3d workloads.
You can take a look at this article, which dissects how Intel ARC cards behave VS AMD cards in D3D11: https://chipsandcheese.com/p/digging-in ... -on-intels
You need a repeatable test environment in a specific graphics API to be able to evaluate 2 driver releases in 1 specific workload (game).
crack
Post by crack » 04 Sep 2025, 14:47
kyube wrote:
04 Sep 2025, 09:00
crack wrote:
03 Sep 2025, 18:36
Oh, right. I can test DOOM Eternal for Vulkan workload, D3D11 Borderlands GOTY Remastered, DX9 S.T.A.L.K.E.R. Shadow of Chernobyl and CoD1 for OGL. What time per testing session should I go for? 30 mins? more? less? right now I don't have time to test.
Post by Slender » 04 Sep 2025, 14:55
crack wrote:
04 Sep 2025, 14:47
kyube wrote:
04 Sep 2025, 09:00
crack wrote:
03 Sep 2025, 18:36
so, 566.03 working for you?
kyube
Post by kyube » 04 Sep 2025, 15:56
crack wrote:
04 Sep 2025, 14:47
You don't need to do long sessions, shorter intervals are sufficient.
You'd set the duration to be exactly the length of the benchmark you're targetting.
The main problem is finding a repeatable testing environment / benchmark.
For example: CS2 (D3D11) benchmark maps, OW2 (D3D11 & D3D12) benchmark maps — HEZHJ & D3KVN can be good games to test driver performance in.
You could also find a D3D12, D3D9, OGL & VK title from here:
https://www.pcgamingwiki.com/wiki/List_ ... benchmarks
https://www.pcgamingwiki.com/wiki/List_of_OpenGL_games
Here's a few examples of games with a built-in benchmarks (taken from the lists above):
D3D12: Ashes of the Singularity, Shadow/Rise of The Tomb Raider, CoD MW3 (2023), RDR2
D3D9: Arma2, UT2004, GTA IV, CS:S, FEAR, Batman Arkham Asylum, Mafia II (original)
OGL: Xonotic, Minecraft, UT2004 (custom), Doom 3
VK: Wolfenstein Youngblood, Doom The Dark Ages
Remember that you are interested in the CPU overhead, meaning you don't want your GPU to be limitation here.
Use lowest graphical settings in-game & lowest possible resolution possible, as a baseline)
I would stick to D3D title tests only, as OGL/VK titles are on DXGI interop (replacing GDI) on Nvidia GPUs
https://old.reddit.com/r/nvidia/comment ... _in_55585/
Note: The DPC/ISR driver performance in 1 title may not apply to other titles of the same graphics API.
crack
Post by crack » 04 Sep 2025, 19:26
Slender wrote:
04 Sep 2025, 14:55
crack wrote:
04 Sep 2025, 14:47
kyube wrote:
04 Sep 2025, 09:00
crack wrote:
03 Sep 2025, 18:36
yes, better than 566.14, although 566.14 did not show the big frametime spikes you speak of, this absolutely feels better off straight away after the shader caching finishes.
