Only at 240Hz. Without DSC, it's limited to 240Hz 8-bit. But uou can still use 180Hz 10-bit with DSC disabled.
DSC Problems & Misinformation [DSC IS NOT A HOAX]
- RealNC
Re: DSC Problems & Misinformation [DSC IS NOT A HOAX]
- Smallsee
- RealNC
The downside is that the 180Hz mode in this monitor is broken when VRR is enabled
primeh0pe
I was actually that guy back in 2023 asking about DSC, and funny enough I ended up searching about it again now because I just got a new 360Hz XG27ACDNG. Been using it for about a week — looks fine and smooth overall — but in shooters I started to feel something weird that I can’t fully explain.
Before this, I had been grinding on my 7-year-old MSI FHD IPS while waiting for the 360Hz QD-OLED. Honestly, I was tapping heads way easier on that old panel compared to this OLED. Not sure if it’s my skill, my eyes adjusting to 2K res, or something else, but I can definitely say there’s something off with OLEDs in competitive shooters. That’s what keeps pushing me back to the idea that maybe DSC (or something about OLED processing) is doing something in Valorant or other shooters.
primeh0pe
The weird part is — when I turned off DSC on this new monitor, my aim actually felt better and I was landing shots more like I did on the old IPS. That’s what keeps pushing me back to the idea that maybe DSC (or something about OLED processing) really is doing something in Valorant or other shooters.
- kyube
I hope you realise that not a single person in this thread has given concrete proof which confirms DSC has “problems” or has a input latency penalty.primeh0pe wrote: ↑06 Sep 2025, 21:37I was actually that guy back in 2023 asking about DSC, and funny enough I ended up searching about it again now because I just got a new 360Hz XG27ACDNG. Been using it for about a week — looks fine and smooth overall — but in shooters I started to feel something weird that I can’t fully explain.
Your anecdote is only an anecdote and cannot be taken as concrete evidence, nor can r0ach's rambling in someone's discord DM's.
There are multiple variables at play when you discuss these differences, it's not a single variable like you think it is.
All of this is easily verifiable with microsecond precision input latency testing, akin to flood's old thread.
These are the articles I've come across which mention the total latency increase:
1st article (claims the difference is 50ns (0,5µs))
2nd article (claims ~3µs)
Can it be more? Yes, the room is open for interpretation
I personally, without any sources to back my claims up, think it's well below <10µs in terms of overall impact on the processing latency chain.
There are much larger fish to catch on the system latency pipeline when you're tuning digital systems to be analog-like.
hazelri
Hi, I'm new to these forums but noticed you have the monitor I'm looking at getting and I'm worried about DSC affecting me negatively. When you disabled DSC. Were you still able to do 360Hz with 8-bit color depth (Since that should be under the bandwidth limit for HDMI 2.1)? Or were you locked out of some options on your display? If you're able to give me any insight on this it would be greatly appreciated, thank you.primeh0pe wrote: ↑06 Sep 2025, 21:37I was actually that guy back in 2023 asking about DSC, and funny enough I ended up searching about it again now because I just got a new 360Hz XG27ACDNG. Been using it for about a week — looks fine and smooth overall — but in shooters I started to feel something weird that I can’t fully explain.
primeh0pe
hi bro the issue apprently is when u have DSC on and its above ur refresh rate so it was only in vALORANT everytime i turn it off i go insane mode and ez click heads But when i have it on It just like so heavy or not smooth idk what u call it anyway When you limt ur fps to ur refresh rate instead of going 1k fps in valorant with dsc on it will feel the same as it is off so it was only a highh fps issue idk if ppl know about it but i notice it But It is fine in tarkov and any other game sm ooth as butter And Yeah no one talk about it igeuss im the only one who know about ithazelri wrote: ↑18 Sep 2025, 11:35Hi, I'm new to these forums but noticed you have the monitor I'm looking at getting and I'm worried about DSC affecting me negatively. When you disabled DSC. Were you still able to do 360Hz with 8-bit color depth (Since that should be under the bandwidth limit for HDMI 2.1)? Or were you locked out of some options on your display? If you're able to give me any insight on this it would be greatly appreciated, thank you.primeh0pe wrote: ↑06 Sep 2025, 21:37I was actually that guy back in 2023 asking about DSC, and funny enough I ended up searching about it again now because I just got a new 360Hz XG27ACDNG. Been using it for about a week — looks fine and smooth overall — but in shooters I started to feel something weird that I can’t fully explain.
pigzera
Im using the acer xv240f6 (600hz with dsc/10bit) and it has the OSD option to enable/disable dsc and i didnt notice any latency/feeling difference between the two. I think on this monitor its well implemented.
- Espionage724
DSC = Display Stream Compression; that's all I'd need to know about it to be figuring out how to instantly disable that
Compression implies decompression somewhere which sounds like more latency than not doing the process. And why would I want anything compressed to the display to have it potentially muddied out to my eyes?
