The full path to fix the problem.
- naporitan
Re: Input lag and desync problem due to RAM?
Always reset clear cmos before installing a new system.
Now I have the latest version of BIOS and Windows 11 Home 24h2. During the system installation, the Internet is disabled to bypass the creation of a Microsoft account. After installation and internet connection, I set my time zone in the time settings and synchronize the time. XMP/EXPO is activated, secureboot/tpm is enabled.
All drivers are downloaded from the official website of the motherboard and the latest version of the GPU driver.
After installing all Windows updates, I launch and update all applications through the Microsoft Store, since among them there are very important components - viewtopic.php?f=10&t=14883&start=60#p118589
The system is activated using the massgrave script.
reflex disabled/fps_max 400/resolution 1280x960 (stretched)
0 tweaks/I don't change powerplan, timers, regedit, bcdedit, etc.
nvidia settings are all default, but I activated GPU scaling and override scaling mode set by games and programs.
benq xl2546, picture mode: gamer 1, Dyac disabled. The driver for the monitor is installed from the official website of the monitor.
I connect the mouse and keyboard to the correct USB ports - viewtopic.php?t=14883&start=90#p119507
Wlmouse Ying (red)
mouse settings: (I warn you that it is not recommended to set debounce time 0ms on mechanical switches.)
I have this value set because my mouse has optical switches.
sens in game 1.6, 800 dpi
mousepad: mgg ultraaceaim xsoft IPI AURORA65 (Silver, Lightning Magnetic Switch)
keyboard settings: all settings are default
1.9kd/140 ping cpu - ryzen 9 5950x
mobo - asus rog crosshair viii hero (wifi)
ram - F4-3600C14D-16GTRGB
gpu - msi 3090 suprim x 24gb
psu - Super Flower Leadex Titanium 850W
cooling - Arctic Cooling Liquid Freezer iii 420mm argb black
ssd - samsung 970 evo plus 500gb
UPDATE: 05 Oct 2025
viewtopic.php?t=14883&start=90#p119293
Wlmouse Ying (red)
UPDATE: 05 Oct 2025
- naporitan
Interesting fact: on a faulty system dyac does not work, you can check this using your phone camera.
On a working system with dyac enabled, there should be horizontal black stripes on the monitor.
When dyac is on, my head and eyes start to hurt.
- naporitan
sens in game: 0,503
reflex disabled
- Slender
hallucinations
MeveSPB
Depending on how you turn the camera over, the lines can be either horizontal or vertical. When dyac is off, they are also there, but less pronounced.
- WhatsApp Image 2025-09-09 at 10.02.05.jpeg (51.17 KiB) Viewed 5927 times
- WhatsApp Image 2025-09-09 at 10.02.05 (1).jpeg (74.7 KiB) Viewed 5927 times
- naporitan
- naporitan
Re: The full path to fix the problem.
Playing with dyac on gives me a severe migraine. It's also as if the stress is increasing.
https://www.reddit.com/r/Zowie/comments ... _eyes_are/
There is no Dyac technology on older benq monitors, but instead there is BFI, which is enabled by default and cannot be turned off, and your eyesight deteriorates very much!
The xl2411p doesn't have Dyac technology, but instead it has BFI, and it's the kind of thing that destroys your brain and eyesight. https://www.reddit.com/r/Zowie/comments ... &context=3
I get severe migraines when Dyac is turned on and stress, but if it is turned off, I always feel good even if I sit all day.
- naporitan
Today I bought a new processor - a Ryzen 7 7800x3d, a B650 Aorus Elite AX V2 motherboard, and an F5-6000j3636f16gx2-tz5rs. I'll be home in a week and check everything out. The previous build is working fine.
donger
Waiting for your evaluation of this motherboard. I am on AM4/5800X3D and have zero problems but switch to AM5 is inevitable.
