HIGH % YOUR InputLag/HitReg IS NETWRK RELATED.
Sz3ypy
Re: HIGH % YOUR InputLag/HitReg IS NETWRK RELATED.
I use Intel I210-T1 do far do good
Watchdog
dermodemon
Holy f*cking sh*t guys.hazzahodgson wrote: ↑01 Apr 2025, 23:34try the one with netadaptercx, not the ndis one, i like netadaptercx oneJimCarry wrote: ↑01 Apr 2025, 16:33hazzahodgson wrote: ↑01 Apr 2025, 14:58I guess you havent much experience with inteupts affinity/policies yet so id research it a bit before you change anything as you can easily make performance worse. it depends a lot on your hardware and how its configured.
Go in advanced network adapter properties and for rss queues, change msi limit for the same amount of queues you have. that make it a bit more stable for me.
however i do notice youre using the same ethernet controller as my motherboard has. You can try the netadaptercx driver. you can download it here https://www.realtek.com/Download/ToDown ... oadid=4342
-I guess you havent much experience with inteupts affinity/policies yet so id research it a bit before you change anything as you can easily make performance worse. it depends a lot on your hardware and how its configured.
i have i use i did put my nic on my last core.
-Go in advanced network adapter properties and for rss queues, change msi limit for the same amount of queues you have. that make it a bit more stable for me.
i dont use rss.if you increase msg limit for some driver and if the irqs dont go up as well it means it does not work.
-however i do notice youre using the same ethernet controller as my motherboard has. You can try the netadaptercx driver. you can download it here https://www.realtek.com/Download/ToDown ... oadid=4342
i use the latest one 2025 the one that you are linking i think is the same but with power savings enable or i am in mistake ?
https://www.realtek.com/Download/ToDown ... oadid=4357
I beat desync with this "netadaptercx" driver.
I disabled all offload, energy savings and interrupt moderation.
Checked MSI box and put it to the core 4(priority low, msi limit 4, RSS 4 queues).
Then i put this command in CS2 launch options "+cl_tickpacket_desired_queuelength 0.035" without " ".
Now i don't have any desync and finally FEEL like my shots are hitting enemies as it should be.
Definitely not a placebo. Whole week without any kind of desync.
I am finally free from this network lag thread.
Such a relief.
P.S. tried USB network card = desync
tried PCIe network card = desync.
After all of that i came back to my onboard lan realtek NIC and with this driver my games (cs2 included) feel amazing again.
MOBO: Asrock B450m PRO4-F
- dervu
Now tell if you tested on same game version to avoid update affecting your "feelings".dermodemon wrote: ↑20 Sep 2025, 08:03Holy f*cking sh*t guys.hazzahodgson wrote: ↑01 Apr 2025, 23:34try the one with netadaptercx, not the ndis one, i like netadaptercx oneJimCarry wrote: ↑01 Apr 2025, 16:33hazzahodgson wrote: ↑01 Apr 2025, 14:58
Such a relief.
dermodemon
Well cs2 got updated 3 times this week. Still feels really good. By the way in the game called Hunt Showdown my desync disappeared toodervu wrote: ↑20 Sep 2025, 10:24Now tell if you tested on same game version to avoid update affecting your "feelings".dermodemon wrote: ↑20 Sep 2025, 08:03Holy f*cking sh*t guys.hazzahodgson wrote: ↑01 Apr 2025, 23:34try the one with netadaptercx, not the ndis one, i like netadaptercx oneJimCarry wrote: ↑01 Apr 2025, 16:33
Such a relief.
Kal
Is this the driver with rss already disabled and not visible when you check the properties?dermodemon wrote: ↑20 Sep 2025, 08:03Holy f*cking sh*t guys.hazzahodgson wrote: ↑01 Apr 2025, 23:34try the one with netadaptercx, not the ndis one, i like netadaptercx oneJimCarry wrote: ↑01 Apr 2025, 16:33hazzahodgson wrote: ↑01 Apr 2025, 14:58
Such a relief.
dermodemon
This driver has RSS enabled by default. I just change it to 4 queuesKal wrote: ↑20 Sep 2025, 18:04Is this the driver with rss already disabled and not visible when you check the properties?dermodemon wrote: ↑20 Sep 2025, 08:03Holy f*cking sh*t guys.hazzahodgson wrote: ↑01 Apr 2025, 23:34try the one with netadaptercx, not the ndis one, i like netadaptercx oneJimCarry wrote: ↑01 Apr 2025, 16:33
Such a relief.
Watchdog
Is there a driver for Intel I210-T1 that has "netadaptercx"?hazzahodgson wrote: ↑01 Apr 2025, 14:58I guess you havent much experience with inteupts affinity/policies yet so id research it a bit before you change anything as you can easily make performance worse. it depends a lot on your hardware and how its configured.JimCarry wrote: ↑01 Apr 2025, 14:46thanks,but i still dont get it,you mean that when for example,when you go in msi util,msg limit when up or ?also when you plug the "realtek 8812bu" in the usb do you change any advanced settings on it or? and what is you cmd?hazzahodgson wrote: ↑01 Apr 2025, 11:25https://learn.microsoft.com/en-us/windo ... interrupts - you can read up on it here
the usb wifi dongle i have is a realtek 8812bu
Sz3ypy
InputLagger
Still fixed till today?dermodemon wrote: ↑20 Sep 2025, 11:49Well cs2 got updated 3 times this week. Still feels really good. By the way in the game called Hunt Showdown my desync disappeared toodervu wrote: ↑20 Sep 2025, 10:24Now tell if you tested on same game version to avoid update affecting your "feelings".dermodemon wrote: ↑20 Sep 2025, 08:03Holy f*cking sh*t guys.hazzahodgson wrote: ↑01 Apr 2025, 23:34
Such a relief.
MOBO: Asrock B450m PRO4-F![]()
