The fix was really unexpected to the point since 2022 I've changed every single part of pc to buying new console , routers tried elsewhere thinking it was electricity and many more things ..etc.. with very temporary improvement, the fix was the sim card i use for my home network to get 4g internet, i was searching in my 4g router and i tried to disable mobile data and after seconds the mouse movement became more precise and controllable before it was unpredictable and keeps changing dpi , i was wtf bro? So i thought maybe its either faulty router of sim card , tried sim card on my mobile and same thing happened, so i went to the company and bought a new one and now the lag is so much better than before , even if you have the sim on your phone and it seems to be working properly but it might be causing these issues, I'll take my sim cards to the company for checking..
Sorry for my english it isnt my native
Solved 75% of input lag and floaty aim
Zwss98
Re: Solved 75% of input lag and floaty aim
Update : removed the sim from father's phone and got a better mouse control and less input lag, so the sim card must be needing update or having some issues, it has to be checked with the company, thank god i found out why my games on all platforms lagging... Its the end
ablemor
this is not the solution( try, flight Mode)
- MaleGigolo
There is no such thing as 75% solved you either fully solve this problem or don't.Zwss98 wrote: β18 Oct 2025, 04:28Update : removed the sim from father's phone and got a better mouse control and less input lag, so the sim card must be needing update or having some issues, it has to be checked with the company, thank god i found out why my games on all platforms lagging... Its the end
amorou
So you didnt try turning off router and playing some offline games before ? ...Zwss98 wrote: β18 Oct 2025, 03:20The fix was really unexpected to the point since 2022 I've changed every single part of pc to buying new console , routers tried elsewhere thinking it was electricity and many more things ..etc.. with very temporary improvement, the fix was the sim card i use for my home network to get 4g internet, i was searching in my 4g router and i tried to disable mobile data and after seconds the mouse movement became more precise and controllable before it was unpredictable and keeps changing dpi , i was wtf bro? So i thought maybe its either faulty router of sim card , tried sim card on my mobile and same thing happened, so i went to the company and bought a new one and now the lag is so much better than before , even if you have the sim on your phone and it seems to be working properly but it might be causing these issues, I'll take my sim cards to the company for checking..
Zwss98
Bro I've tried everything comes to the human mind to the point i was about to give up thinking it was my body causing it bcuz nothing left to blameamorou wrote: β18 Oct 2025, 18:43So you didnt try turning off router and playing some offline games before ? ...Zwss98 wrote: β18 Oct 2025, 03:20The fix was really unexpected to the point since 2022 I've changed every single part of pc to buying new console , routers tried elsewhere thinking it was electricity and many more things ..etc.. with very temporary improvement, the fix was the sim card i use for my home network to get 4g internet, i was searching in my 4g router and i tried to disable mobile data and after seconds the mouse movement became more precise and controllable before it was unpredictable and keeps changing dpi , i was wtf bro? So i thought maybe its either faulty router of sim card , tried sim card on my mobile and same thing happened, so i went to the company and bought a new one and now the lag is so much better than before , even if you have the sim on your phone and it seems to be working properly but it might be causing these issues, I'll take my sim cards to the company for checking..
- MaleGigolo
Lol reading this thread again reminded me of x7007 and his shenaningans on OC forum. Anyone here knows who I'm talking about? This guy would make a new thread every day with the title "Solved by %" and every day the % would rise and sometimes go back but at the end before his thread got locked he managed to solve this problem by 90%!!!
