i know, body can eliminate 50hz wave but only if you touch something metal part. But, you can take multimeter, and measure voltage between your body and neutral / ground in socet (also between neutral and ground), measure voltage between body and pc. Also, when you make that, try measure with foot on floor, without foot on floor.astroasis wrote: βYesterday, 23:22Yes, no issues with hardware grounding in my opinion. My pc has been on for 12 hours and mouse movement has stayed the same throughout, which is newSlender wrote: βYesterday, 17:57pc is grounded?astroasis wrote: βYesterday, 13:46I only tried it for the first time today, ive had the issue since 2018 and its followed me to different parts of the UK which makes no sense. As soon as I got back to my flat today after the experiment I noticed all text and visuals were clearer and that shadow that follows the mouse cursor was less apparent, cs2 and battlefield 6 were smoother, like there were more frames and movements happening in the game not just the fps. If the desync comes back I'll go touch grass barefoot again and see what happens, this would suggest our physical body is messing with electronics somehow
How I solved my particular input lag,floaty mouse,desync, degraded visuals problem
Re: How I solved my particular input lag,floaty mouse,desync, degraded visuals problem
I may try that multimeter test if it gets bad again, for now I can see a difference day 2, even opening tabs in chrome looks smoother, youtube videos, windows explorer etc. WASD movement in cs2 feels more normal, there are complete frames of animation missing with the desync but no test will show itSlender wrote: βToday, 06:31i know, body can eliminate 50hz wave but only if you touch something metal part. But, you can take multimeter, and measure voltage between your body and neutral / ground in socet (also between neutral and ground), measure voltage between body and pc. Also, when you make that, try measure with foot on floor, without foot on floor.astroasis wrote: βYesterday, 23:22Yes, no issues with hardware grounding in my opinion. My pc has been on for 12 hours and mouse movement has stayed the same throughout, which is newSlender wrote: βYesterday, 17:57pc is grounded?astroasis wrote: βYesterday, 13:46
