d4rthvdr
Post
by d4rthvdr » 27 Feb 2025, 00:17
bigE wrote: ↑07 Jan 2025, 17:46
bigE wrote: ↑01 Jan 2025, 21:16
Hey guys,
I'm new to owning a VG259QM. The last monitor I had was 144hz asus monitor. I was wondering if I should leave OC on and run 280hz all times? Will this lower the lifespan of my monitor or even damage it at all? Or should I just run at 240hz all the time? I'll be using this monitor mostly for gaming, so would be bit of a pain to switch back and forth. I'd rather just run a constant hz. That's why I'm wondering if I should just use this at 280hz all the time or if that will end up having negative effects, then should I just run at 240hz all the time??
Thanks!
I decided on going with 240hz, as I found maybe some increased lag when trying to run 280hz all the time. My PC in most games I play can get upwards of 280 fps, but in most cases is more around 240 fps.
Anyway, I will be returning this monitor. I've been using it for a week and it already has a dead pixel on the screen. Just ridiculous. ASUS's warranty states that the monitor needs 3-5 dead pixels for it to be fixed. Insane.
about lifespan. there are a lot of people that use this panel for years with OC+ overdrive 120 and there is no problem at all 100%. to be short OC won't damage the monitor.
about hz. i play mostly an old game (quake live with stable 250fps) and i can firmly assure you that any other option except 280hz provides huge input lag. this panel is a pure treasure only at 280hz
gsk03111
Post
by gsk03111 » 06 Mar 2025, 14:00
speancer wrote: ↑14 Apr 2021, 10:38
Hey guys, the search doesn't give me results, what's the panel name of your VG259QM? I just got a new unit of this monitor yesterday and I'm not sure if the panel is the same. Seems like this unit is a newer batch (Dec 2020, previously had all from Nov 2020 I think). The panel name on my unit is Qisda Q250HAA00. Is it the same?
Hi, new to the forum here.
I've also got the VG259QM, how do I check the panel's name? How can I get the OSD that appears in this photo, or is it a different app? Thanks in advance.
Grembi
Post
by Grembi » 19 Mar 2025, 02:36
Hello everyone,
I can get VG259QM with old Qinsa panel. Do you think these days it is still better choice than AOC 24G2Z or iiyama GB2590HSU?
daniel33
Post
by daniel33 » 10 Aug 2025, 11:00
Hello,
I recently bought a VG27QM monitor, and it currently has the MCM101 firmware installed. How good is this firmware? How can I update the firmware on this monitor? Also, is there any problem if I perform the steps mentioned in the first message?
virten
Post
by virten » 25 Oct 2025, 12:44
Hello there. Please, what is the best BF6; settings for this monitor? I have around 170-220fps in game.Now i have settings for 280hz because recently i played Valorant.
axaro1
Post
by axaro1 » 26 Oct 2025, 13:46
virten wrote: ↑25 Oct 2025, 12:44
OD60, VRR ON, 276fps cap, ELMB-Sync OFF
virten
Post
by virten » 29 Oct 2025, 02:13
should i cap fps when i dont almost reach them? VRR you mean G-Sync ? I’ll just add, wouldn’t it be better to set Battlefield 6 to 240 Hz, since I currently have 280 Hz but don’t have a stable 280 FPS in BF6?
pigzera
Post
by pigzera » 15 Nov 2025, 08:12
Just moved from VG279QM to Acer XV240 F6. Didnt found any reviews online, only some chinese videos. Its a 24' 600hz TN panel. The image quality is not far from the ips, the PPI is a bit better and i saw a very noticiable increase in text quality, input lag is a bit better than the asus and the motion clarity with VRB (extreme) is awesome, it looks surreal. VRB has two settings; normal or extreme. The brightness is higher than the asus ELMB at max brightness. Also, overdrive has two options normal and extreme. The last one has a bit of overshoot but its not so noticiable, but i set it on normal. When i first got the asus i tried ELMB with 280hz and it was impressive but now it is in another level lol, theres basically no ghosting or blur.
Theres a DSC toggle, if you disable it gets limited to 540hz. Im using this with a RTX 4070ti and the included displayport 1.4 cable.
The OSD is good, but i missed some basic settings like sharpness slider and deep sleep setting.
Paid about $600 (in Brazil R$3800). I know its very expensive but where i live the tax are absurd and we dont have many options. Theres some entry level/first gen OLEDs at $800 or higher but i wanted to try 600hz.
pigzera on 14 Jan 2026, 12:14, edited 1 time in total.
Gildeone
Post
by Gildeone » 13 Jan 2026, 15:20
Greetings from Brazil.
I have the VG259QM and I'm playing BF6 at 100-130fps. Any recommendations for refresh rate and OD?
Thanks!
BLUR-SENSITIVE
Post
by BLUR-SENSITIVE » 19 Feb 2026, 05:02
I have owned this monitor for years (Qisda panel) & had no issue until recently started running somewhat hotter-than-usual. Things also got blurrier, for anyone else who encounters this my somewhat fix so far was to switch to the official ASUS device driver, step down to 270hz/240hz, Perform scaling on GPU instead of display & enable ELMB. (optional move to the secret OD 120). If anyone has any tips or info I'm listening please lmk.
VG259QM [Qisda]
