Went from Bufferbloat C rating to A+ rating with this script! NIC only tweaks!
ArkoN
Post by ArkoN » 10 Nov 2025, 13:41
Hello everyone
I have to share something I just discovered and maybe very helpful for others. I have a 10 Gbit Fiber Connection and Im connected with 2.5 GBit LAN to the Router.
My Bufferbloats results are from B to C with very bad upstream. My CS2 feels horrible sometimes because of it. Unfortunately I cannot change to router or put it into Bridge mode, which sucks. So no QoS, SQM possible on this setup.
Here is a Bufferbloat:
Then I did write a Script to optimize my NIC Settings and these are the results after running my script:
Its insane how much better it got, also the speed is reduced as it would do some kind of SQM. For Online Gaming this is perfect! I dont need the speed I need the stability!
The Main command that changed this was:
netsh int tcp set global autotuninglevel=disabled
The script does the following:
Disabling EEE, Interrupt Moderation, LSO, Adaptive IFS, RSC, and SIPS
Keeping Flow Control enabled
Enabling RSS
Writing registry latency tweaks (TCPNoDelay, TcpAckFrequency, NetworkThrottlingIndex)
Restarting the NIC automatically
Printing a detailed summary for verification
I did write the Script with ChatGPT, here is the original Version that only works with Intel Nic 225:
https://pastesapp.vercel.app/pastes/mhthb7ah9sbi73jqjm5
This should work with all other NICs but is not tested yet:
https://pastesapp.vercel.app/pastes/mhthlemvg8q88ed9ys
SYSTEM: AMD 9950 X3D, ASUS LC RTX5090 OC, ASUS X670E-F, 2x16GB Lexar CL28 on 6200, Asus XGF27AQWDPG
Lev1n
Re: Went from Bufferbloat C rating to A+ rating with this script! NIC only tweaks!
Post by Lev1n » 19 Nov 2025, 11:24
those links are doesnt workin
Tell
Post by Tell » 19 Nov 2025, 12:09
So adjusting TCP autotuning level made your game that uses UDP packets feel better? :|
ArkoN
Post by ArkoN » 19 Nov 2025, 14:07
Lev1n wrote:
19 Nov 2025, 11:24
I just checked them, they are working
ArkoN
Post by ArkoN » 19 Nov 2025, 14:11
Tell wrote:
19 Nov 2025, 12:09
Its called PLACEBO ;-)
Mr_Mir
Post by Mr_Mir » 19 Nov 2025, 16:16
ArkoN wrote:
19 Nov 2025, 14:07
Lev1n wrote:
19 Nov 2025, 11:24
https://imgur.com/a/kngB8bn
This is what I see from your link
Post by Slender » 19 Nov 2025, 18:21
where you unreaz?? another guy say that settings working for him in games but that is tcp connection, how you explain that??
[email protected]
Post by [email protected] » 20 Nov 2025, 02:58
Tell wrote:
19 Nov 2025, 12:09
Bufferbloat: Bufferbloat is a network latency issue caused by excessive queuing of data packets in a device's buffer, which can cause high latency (lag) and jitter, even on high-speed internet connections.
If your bandwidth is completely utilized, all packets being sent at that time will be slowed down.
Using "netsh int tcp set global autotuninglevel=disabled" deoptimizes its TCP bandwidth so that UDP packets have space.
dervu
Post by dervu » 20 Nov 2025, 04:39
Ok, but that is work for router, so you don't have to worry if it's your PC or other in the network causing spikes.
Ryzen 7950X3D / MSI GeForce RTX 4090 Gaming X Trio / ASUS TUF GAMING X670E-PLUS / 2x16GB DDR5@6000 G.Skill Trident Z5 RGB / Dell Alienware AW3225QF / Logitech G PRO X SUPERLIGHT / SkyPAD Glass 3.0 / Wooting 60HE / DT 700 PRO X || EMI Input lag issue survivor (source removed) 8-)
[email protected]
Post by [email protected] » 20 Nov 2025, 05:30
He tested the bufferbloat on his PC and solved the bufferbload, if he is gaming and downloading at the same time.
