Best Blue Light Blocking Glasses – Need Expert Advice
kimkon
Post by kimkon » 08 Jan 2026, 07:08
I researched the best blue light blocking glasses for the past few days because I spend long hours in front of a computer and mobile screens and want to reduce eye strain and improve sleep quality. I read reviews on trusted sources like The New York Times (Wirecutter), Consumer Reports, and popular tech and health websites, and they are consistently marking these two options as the best choices:
Felix Gray Blue Light Glasses
Felix Gray Carver Blue Light Glasses
Both are highly rated for comfort, lens quality, and effectiveness in reducing digital eye strain. However, I’m having trouble deciding which one would best suit my needs and would appreciate expert advice. At home and work, I use laptops, smartphones, and monitors for many hours daily, and I’m looking for glasses that are comfortable for long use, effective without distorting colors too much, and suitable for everyday wear.
So which one should I buy? Any recommendation or real user experience would be appreciated. Thanks in advance.
