Positive vibes :
For years I’ve used a 34" Dell ultrawide 144 Hz, and I’ve never had any eye strain issues with it.
I can work and game for hours without discomfort. Same with my laptop (different sorts of laptops old acer/old dell latitudes/new dell laptop and phone (galaxy s3,iphone 6s,iphone 11,iphone 14 pro max) — no problem at all.
I also do have 2x 27 inch dell u2415 - no problem with them.
In the past i've had some older 27 inch dell monitors with thick panel , don't remember the model - they were producing good amount of heat - no problem with them too , eyes were feeling comfortable.
+ to all that i have built another setup for my wife with 34 inch lg monitor and two 24.5 dell monitors - i have no issues looking at them.
Broken eye vibes
Now , i've decided to start playing cs2
So i've decided to go with :
Alienware AW2524HF (Fast IPS, up to 500 Hz) for competitive gaming. With that monitor, I started experiencing burning eyes, dryness, and strong light sensitivity within 5–15 minutes, even on the desktop. The discomfort would persist for a while even after turning it off. I tried lowering brightness, changing refresh rate, disabling enhancements, adjusting room lighting — nothing really solved it.
I returned that monitor and switched to a XL2566X+ , which feels better than the Alienware, but I’m still more sensitive than I used to be on my old 34" Dell.
I've tried so many things , reducing hz/disabling dyac and other sharpness features/went through several guides/callibration/setting up proper light source and etc. - nothing helps , while with my34 inch screen i can sit in the darkness and my eyes are chilling...
Question
Now i'm thinking what's next.. i have few days left to test benq zowie, but i think i won't keep it, should i go with OLED? or any ideas , i took this TN panel because of lots of positive feedback from people who were writting about eye strain with IPS panel , but now i'm bit confused , Dell 500 hz ips panel was melting my eyes, benq zowie tn panel is also melting my eyes but more gently
by the way, months ago we've purchased a TV TCL 75Q10B - it was also badly affecting my eyes.
I have no issues with my sight, doing checkups at the doc. all good.. it just that some panels are killing me , and dissapointing..
any ideas on this story ?
many thanks in advance !
