Hello everyone,
first, my System:
9800x3D
96GB DDR5 RAM
RTX 5090
I've had horrible micro-stutters in Windows 11 specifically.
This was a big reason why I used Linux only for the last couple of months and stopped playing specific games that require Anti-Cheat and don't work on Linux.
Well...
6 Months ago I got a new keyboard and mouse.
The keyboard and the mouse both support 8000 Hz polling rate. I had kept the keyboard at 8000 Hz since it's wired. So I thought: No need to worry about the battery. The mouse I had usually used around 1000 or 2000 Hz due to battery drain.
Today, I watched some videos on the topic and realized that it's probably an overrated feature to use more than 1000 Hz.
So I tried this out: I switched both to 1000 Hz explicitly.
And let me tell you:
EVERY single micro-stutter in CS2 was GONE!
It is now perfectly smooth (as it should be, considering my hardware). Not only this, even certain micro-stutters within Windows 11 itself are gone! The entire system just feels a lot more responsive and alive! Comparable to the Linux counterpart.
I will say: In Linux, it was already buttery smooth. So it's probably "okay" to use 2k to 4k Polling with Linux. It's just better overall and can deal with it. But I'll still keep it at 1k Hz because clearly it's not working properly in CS2. I'll try in Linux with the new settings again to see if it even improved there.
But if you have a modern keyboard and mouse, PLEASE check your settings and turn it down to 1k Hz! It causes horrible stutters and lags! And the Frametimes don't actually show this. Frametime did not change significantly before or after. But the game just feels a lot better now!
Big reason for micro-stutters discovered! High end System
rnk0
rnk0
Re: Big reason for micro-stutters discovered! High end System
Here to confirm:
Even on Linux, it made a BIG difference! Definitely DON'T use more than 1000 Hz! A less than 1ms response-boost for possibly WORSE than 1ms of added latency from framedrops and issues...not worth it!
- Espionage724
My 8th-gen i5-8400H handles a 8K mouse no problem (no noticeable performance difference 1000Hz -> 8K).
I suspect it's something like IOMMU, Ryzen CPU USB vs over PCH, or some random BIOS setting (probably something fun with all the cores and RAM with allocation/scheduling). I know Ryzen had flaky USB X400 and heard it still X500, so I'm a little skeptical of AMD boards having ideal USB settings, or they might require heavy tuning (I bought a PCI-E USB card to workaround X470 USB)
- kyube
Nice troll.
Try not tuning your system to the point of instability (DRAM tuning or CPU tuning in UEFI) and suddenly 8kHz (ISR interval=0,25ms) works great across multiple games.
My i7-3770k rig runs 8kHz with zero sweat.
It's not related to CPU vs PCH ports.
It's simply a user error in hardware tuning.
rnk0
Wdym nice troll?kyube wrote: ↑29 Jan 2026, 14:02Nice troll.
It's not a troll.
My RAM and CPU is finely tuned and stability tested to be 100% rock solid. 0 crashes from that. Memtest done and other various CPU benchmarks.
This issue is specifically about 8k Hz causing micro stuttering.
You could have it too, except your base framerate is too low to even notice it. In my case, 600 FPS felt bad due to this.
You have a 3770k. That is an extremely old 4 core CPU. I doubt you'd push more than 100 frames in cs2. My complaint was that it sometimes felt as choppy as 100 fps. If that's "good" for you, then you won't necessarily notice the difference. That being said: I would 100% recommend turning it down to 1k.
rnk0
Interesting, that could certainly be a possibility!Espionage724 wrote: ↑29 Jan 2026, 13:06My 8th-gen i5-8400H handles a 8K mouse no problem (no noticeable performance difference 1000Hz -> 8K).
Can anyone with a Zen4 or Zen5 system try this out so we can have more datapoints?
- kyube
Provide a ZenTimings SS, what exact tests you've done & for how long you've done them.
Hope you understand that even if you've done 24h in a particular subset of tests, that doesn't guarantee a transfer over into games with their particular memory access patterns.
It varies a lot by system. On an old i7-7740 the 8000Hz is terrible, but on a 9800X3D, the 8000Hz is quite decent.
However, I recommend no more than 2000-4000 to make the Hz improvements outweigh the problems.
Using only 1000Hz sabotages a 720Hz OLED, with lots of jittering due to 720Hz OLED being too close to 1000Hz pollrate.
For best results, it's best to supersample the mouse pollrate at least 3-4x above your display Hz.
This one is about jitter, not about latency.
Also, Valorant's RawInputBuffer feature in Windows is MUCH better than CS2 in handling 8000 Hz.
