I'm sure there's posts I should read first and I've used the search feature, but I'm honestly overwhelmed, sorry.
The situation:
TL;DR - I've always felt like slow displays with full on ghosting are easier to look at than high refresh rate displays with just blur, but recently I've been struggling with my monitor. Using a CRT shader or a motion blur shader helps a tiny bit, but they're not real solutions, so I'm wondering if there's any path for me to take that isn't "take on debt to try out OLED just in case". My main concern about switching to other displays in the same price range is the input lag, which is excellent on the XG2431.
My eyes can't tolerate the motion blur generated by the 240Hz IPS Viewsonic XG2431 regardless of settings (like, really regardless, I promise I've tried everything I could find over days of tinkering and research). They freak out because they can't focus on anything since it's all blurry.
Back when I switched from some 60Hz Benq to a 144Hz TN Asus VG248QE, I had already noticed that the old display was easier to parse for my eyes - choppy motion with ghosting vs smooth motion with blur. The former is easier for my eyes/brain, probably because the obvious afterimages create a backdrop for the moving object itself, which is the sharpest part of the image. It looks terrible, don't get me wrong, but I don't get dizzy looking at it.
Initially, I didn't really feel like the Viewsonic created any side effects, but I've been struggling with it over the last few months, around 2 years after the initial switch. Like I said, I always thought 60Hz was easier to look at in an odd way, but I've never felt actively uncomfortable looking at a monitor until now.
I've found one thing that helps a little bit, and that's Shader Glass. It's an overlay that allows you to use shaders like retroarch CRT effects system wide. Oddly, applying a CRT mask (with no other effects, just a dense pattern of darker spots) helps a little, though it significantly increases eye strain when there is no motion. The other shader that's helped is a motion blur effect, but it's not super great and I'm only starting to experiment with it.
So, any advice for me? I've been thinking of trying to swap my current display for a TN panel to see if that's the difference maker since I've seen that mentioned as a possibility, but I kind of doubt that will do much for me, and I'm pretty worried about how well I'd get along with alternatives in the same price range - the XG2431 has really low input lag, and that was my main reason for switching to it alongside the Asus's terrible colour performance.
I'd appreciate any guidance on the overall topic as well as sidegrade path suggestions. Thanks!
Viewsonic XG2431 and disorientation/dizziness/trouble focusing vision with motion
Ope5
jenkins40
Re: Viewsonic XG2431 and disorientation/dizziness/trouble focusing vision with motion
If blur at 240Hz is bothering you more than ghosting, it might be worth trying a lower refresh rate like 120Hz or 144Hz with a fixed overdrive setting to see if that reduces the perceived smear. You could also test a different backlight strobing mode if available, since that can improve motion clarity without switching panels entirely.
- kyube
Could you detail which specific displays work for you and which ones don't?
What mode of operation they're running at (impulsed - LightBoost/ULMB/PureXP/DyAc or sample&hold - stock for all LCDs/OLEDs)
Do you have any medical conditions?
What games / content were you playing when experiencing said phenomena?
Ope5
I've tried that, lower refresh rate is worse on this monitor because it's the response time that matters in the end. I think... Overdrive settings just introduce bright artifacts without improving clarity imo, and BFI didn't help either (that's strobing, right?)jenkins40 wrote: ↑25 Feb 2026, 04:10If blur at 240Hz is bothering you more than ghosting, it might be worth trying a lower refresh rate like 120Hz or 144Hz with a fixed overdrive setting to see if that reduces the perceived smear. You could also test a different backlight strobing mode if available, since that can improve motion clarity without switching panels entirely.
I didn't really see a major improvement with BFI on my current viewsonic or the previous asus, and haven't used any other displays that support that kind of feature. The monitors that "work" are anything from a cheap laptop screen to an OLED smartphone, and the TN Asus which was mostly okay like I mentioned.kyube wrote: ↑25 Feb 2026, 07:47Could you detail which specific displays work for you and which ones don't?
I don't have any conditions I'm aware of other than nearsightedness and slight astigmatism.
Content wise 2d games with semi fast camera movements have been the worst, but anything with enough camera movement is enough, though fps games are the least troublesome since the bigger movements are also shorter. Sports footage is also dreadful, since it also involves long panning.
- kyube
Because the only 'usable' backlight strobing setting on the XG2431 is 240Hz with PureXP Extreme or Ultra.
Can you be a bit more specific on the exact models name?
Is the laptop a IPS or TN LCD? What laptop model?
What exact phone model?
The reason I'm asking this is because the reason might still be flicker related, as the XG2431 has slight ~2KHz light flicker which you might be sensitive to.
Any video content is bound to be either:Ope5 wrote: ↑25 Feb 2026, 12:15I don't have any conditions I'm aware of other than nearsightedness and slight astigmatism.
- Blurry (as it's all <60FPS content; sample & hold is akin to permanent vaseline applied)
- Stuttery (if you use BL strobing@240Hz; you'll remove the vaseline but you'll have the phase-shift-like artifact; worthy price to pay IMO)
Ope5
The phone is a realme 12+ 5G, laptop's a Lenovo Ideapad 330-15arr, whose display doesn't look like what I expect an ips screen to be, but it's basically impossible to find any information on it.
- kyube
The reason I've asked such information is to see whether you have a specific LCD subtype which you might subconsciously be more preferring.
The XG2431 has this nagging ~2kHz PWM flicker, which you also might've been sensitive to.
Panel coating could also be an issue, though considering that you've used the VG248QE, those things I've mentioned above are likely not the case.
Can you find a XL2540X+, XL2566K or XL2566X+ in your region?
I don't know your exact use-case to give you a perhaps more appropriate model, so I've given you a recommendation based on LCD subtype.
The AOC Q25G4SR might also be satisfactory... maybe... it's sadly about trial & error to some extent...
Ope5
Those first three are a bit pricy for me, but I'll think about it. What makes the aoc a possible candidate? No 2k flicker?kyube wrote: ↑02 Mar 2026, 14:06
