my Omen 27qs has started to develop a slightly warm yellowish tinge in sRGB mode. Whites are not fully white and there's a slight hint of yellow as if a blue light filter is on. When I switch to wide gamut (Native mode), the issue goes away but I get eyestrain from wide gamut mode in monitors.
I read about red phosphor recently and how some IPS monitors use it to improve colors and that can cause eyestrain. I recently tried the pulsar Acer predator XB273U which had excellent sRGB mode colors out the box and was comfortable on my eyes. Unfortunately I had to retrun it cuz pulsar still gave me eyestrain after extended gaming sessions. Is there a way to confirm if either of these monitors have red phosphor? I suspect the Omen 27qs does have red phosphor which is why it's giving me issues and the Acer predator XB273U does not.
Can red phosphor cause eyestrain and color issues in monitors over time?
Omen 27qs: color issues, wide gamut eyestrain, red phosphor questions
Argus
- kyube
Re: Omen 27qs: color issues, wide gamut eyestrain, red phosphor questions
The Omen 27QS is a KSF/PFS WLED backlight model.Argus wrote: ↑25 Mar 2026, 07:45my Omen 27qs has started to develop a slightly warm yellowish tinge in sRGB mode. Whites are not fully white and there's a slight hint of yellow as if a blue light filter is on. When I switch to wide gamut (Native mode), the issue goes away but I get eyestrain from wide gamut mode in monitors.
The Pulsar QHD@360Hz models (ASUS XG27AQNGV, ACER XB273U F5, AOC AG276QSG2, MSI 272QRF X36) are all ̶Q̶D̶ ̶W̶L̶E̶D̶ ̶b̶a̶c̶k̶l̶i̶g̶h̶t̶ ̶m̶o̶d̶e̶l̶s̶.̶ (WRONG INFO: SEE UPDATE)
Pulsar (VRR+PWM) is a extreme eye comfort concern, despite how many reviewers online try to purport it as some “holy grail” solution to battling S&H blur & tearing (which it is bad at)
If you don't have issues with the Acer (QD) during non-Pulsar use, then your issue lies in something else. Not the wide color gamut aspect.
It seems that there's a possible correlation in that regard, yes.
Some users here have reported feeling at ease when swapping to a QD backlight model. Sometimes, a YAG phosphor (narrow color gamut, classic backlight) is necessary.
Whether it's caused due to some other variable not accounted for or the backlight type, I don't know.
Argus
Thanks very much for the info.kyube wrote: ↑25 Mar 2026, 08:47The Omen 27QS is a KSF/PFS WLED backlight model.Argus wrote: ↑25 Mar 2026, 07:45my Omen 27qs has started to develop a slightly warm yellowish tinge in sRGB mode. Whites are not fully white and there's a slight hint of yellow as if a blue light filter is on. When I switch to wide gamut (Native mode), the issue goes away but I get eyestrain from wide gamut mode in monitors.
The Pulsar QHD@360Hz models (ASUS XG27AQNGV, ACER XB273U F5, AOC AG276QSG2, MSI 272QRF X36) are all QD WLED backlight models.
How do you tell if a monitor is a QD WLED backlight model and is there something like the Omen 27QS but with that model instead? It's a shame I returned the acer pulsar monitor but spending that much just to not use pulsar seemed a bit silly to me even if it was very comfortable without pulsar. I'd love to have a monitor as comfy as that one at a better price point and at 1440p 240hz no DSC.
- kyube
See: viewtopic.php?p=120085#p120776
Why not use the ULMB2 setting at 240Hz instead? It's still one of the few rare LCDs which is able to go past 4,166667 ms MPRT with the ULMB2 setting enabled.
+240Hz QD LCDs (non-MiniLED) are extremely rare on the market. They were borderline extinct, till the arrival of these Pulsar models
Argus
ah goddamn I should've kept my pulsar monitor then haha I'm dumb. I hope newegg won't get suspicious if I order something I returned lolkyube wrote: ↑25 Mar 2026, 09:32See: viewtopic.php?p=120085#p120776
+240Hz QD LCDs (non-MiniLED) are extremely rare on the market. They were borderline extinct, till the arrival of these Pulsar models![]()
- kyube
I want to update this topic, as I've recently seen the spectral power distrubtion graph of the new Pulsar models.
It's using a YAG phosphor backlight, not QD.
As per this post
Argus
Thanks for the update.kyube wrote: ↑31 Mar 2026, 08:20I want to update this topic, as I've recently seen the spectral power distrubtion graph of the new Pulsar models.
As per this post
I'm getting another acer pulsar monitor today so I'll update soon as well. I just hope it doesn't have bad backlight bleed because the one I returned was almost flawless and I'm kicking myself so much for that lol.
Paying the niche tax yet again
