You connect the i210 fiber optic pcie lan card to any empty PCIE slot, tighten the bolts, then you get a SFP cable that you plug into the one port on the card and the other on the router's SFP port, if it has an sfp port. I have no idea what router you have, you might need a SFP to CAT(6a, 7, 8 I have no idea which you have, it's written on your cable) adapter.oenay wrote: ↑21 Nov 2025, 21:22How to connect this i210 fiber optic pcie. I have fiber connection. It goes to my router from router it goes with ethernet rj45 cable to my pc? When i put this on my pc how do i connect it from my router to this sfp portfaust123 wrote: ↑20 Nov 2025, 11:15Main reason is electrical courent on twisted pair. Can be caused by POE on ISP switch and other things.
To fully solve your problem I would recomend to buy:
1) Media converter rj45 to sfp
2) PCI-E sfp lan card *.
3) Couple sfp 1gb adapters
4) Fiber optic patch cord
* If you play CS/Valo best for 1gb connection is Intel i210 Fiber Optic PCIE because of anticheat compatibility.i play cs2
disabling ethernet and unplugging fixes sharpness/blurryness/input lag
crack
Re: disabling ethernet and unplugging fixes sharpness/blurryness/input lag
Misha1337
Slender wrote: ↑21 Nov 2025, 19:08yes, mean that.Misha1337 wrote: ↑20 Nov 2025, 09:37Do you mean this? https://a.aliexpress.com/_EHVOIWuSlender wrote: ↑20 Nov 2025, 07:41if default lan / wan has power delivery dc line (5v/12v), it can make sence.rekaa02511 wrote: ↑20 Nov 2025, 05:54I have no idea why but it's night and day difference, sharp image, no blurryness and input lag is gone.. I posted 1-2 weeks ago about (https://komodoplatform.com/en/) completely stuttering when entering their website but now its full smooth and no issues.
How can this be possible?
you can try find ethernet surge protector (with metal shield rj45) and ground it on PE or N in your socet.
do you use wifi mode to play online?
Wouldn't the UPS network surge protector RJ does the same?
ups had metal rj45 port?
Not sure if it's metal or not am running APC BGM2200B-GR Back-UPS Pro for Gaming, 2200VA/1320W, Tower, 230V, 4x Schuko and 2x IEC C13 outlets, RGB Lights, Pure Sine Wave that has surge protection RJ 45 ports in the back
rekaa02511
It's still good, I cant believe all I had to do was switch to WiFi.. Everything is smooth, i can't feel any input lag but I have to deal with 5-7 more ping
The other devices connected to the WiFi now runs smoother too, very very odd. I could feel the input delay on my iPhone before and now nothing. If someone has any better explanation than the previous replies i would love to hear it.
rekaa02511
I have no idea what any of this.. whats the most simple solution of these?faust123 wrote: ↑20 Nov 2025, 11:15Main reason is electrical courent on twisted pair. Can be caused by POE on ISP switch and other things.
cursedgamer12
did this fix everything for you ? hitreg/desync/input/output? thinking about tryingfaust123 wrote: ↑20 Nov 2025, 11:15Main reason is electrical courent on twisted pair. Can be caused by POE on ISP switch and other things.
