Should I use vsync in frameskipping test?
judgeholden13
Post by judgeholden13 » 12 Apr 2026, 15:02
recently I bought a monitor with 240Hz. I decided to test the frame skipping of the monitor, and when I was testing without VSync I saw tearing (which is normal), but I also saw black squares between the white ones. I thought maybe it was about the wrong sync of the test site, so I enabled VSync and it looked correct, I didn't see any black squares or tearing.but usually I don't want to use vsync in games, and if I don't use it will I see frame skipping?"
test site is blurbusters
Re: Should I use vsync in frameskipping test?
Post by RealNC » 13 Apr 2026, 00:11
TestUFO relies on vsync. It doesn't work correctly without it.
judgeholden13
Post by judgeholden13 » 13 Apr 2026, 14:34
RealNC wrote: ↑
13 Apr 2026, 00:11
without vsync I am seeing frame skipping in the test, so will I play the game with frame skipping?
I am worried about it, other wise I would refund it
Post by RealNC » 14 Apr 2026, 02:16
judgeholden13 wrote: ↑
13 Apr 2026, 14:34
Vsync has nothing to do with the monitor. The monitor doesn't even know what vsync is. Vsync is something done by the GPU, not the monitor. If there's no frame skipping with vsync enabled, there's not gonna be frame skipping with vsync disabled either.
But TestUFO absolutely needs vsync in order to sync the frames to the display.
judgeholden13
Post by judgeholden13 » 14 Apr 2026, 15:17
RealNC wrote: ↑
14 Apr 2026, 02:16
13 Apr 2026, 14:34
sometimes without vsync I don't see frame skipping in the test, but sometimes I do why is it like this? and it never changes if dont has been past long time
Post by RealNC » 15 Apr 2026, 06:27
14 Apr 2026, 15:17
Anything can happen when the test cannot sync, including it looking correct.
judgeholden13
Post by judgeholden13 » 15 Apr 2026, 10:53
RealNC wrote: ↑
15 Apr 2026, 06:27
14 Apr 2026, 15:17
so how can I test my frame skipping ratio without using browser, which alternates we have?
Post by RealNC » 15 Apr 2026, 17:10
15 Apr 2026, 10:53
I don't know. Just use vsync to test.
I don't see what the problem is.
judgeholden13
Post by judgeholden13 » 17 Apr 2026, 04:05
RealNC wrote: ↑
15 Apr 2026, 17:10
15 Apr 2026, 10:53
I understand, thx for everything
