Everything about latency. This section is mainly user/consumer discussion. (Peer-reviewed scientific discussion should go in Laboratory section). Tips, mouse lag, display lag, game engine lag, network lag, whole input lag chain, VSYNC OFF vs VSYNC ON, and more!
Input Lag Articles on Blur Busters.
jterri
Post
by jterri » 13 May 2026, 00:11
MK92 wrote: ↑01 May 2026, 03:39
f1ndus wrote: ↑01 May 2026, 03:09
zeasty09 wrote: ↑28 Apr 2026, 18:57
f1ndus wrote: ↑28 Apr 2026, 13:36
but this guy didnt asked CHATgpt for options...
i am giving him 9 years of resources and experiences
9years of resources if you show proof that you have fixed it with new pc in new place...
not just predictions and copy pasta from other people
I didnt fixed it by moving to another place. I alwayse took my PC setup and pheriferals with me, alwayse next day problem become again same as in my house.
I changed many many times apartment, houses but is it still same
https://justpaste.it/9gtp3 "
I read your 2021 post, that "The long version" paragraph is a textboox high wiring impedance / harmonics problem, and it was caused by your neighbours installing something that emits a lot of low frequency noise into the line...let me guess, your apartment at that time was old with shrared neutrals and TN-C installation. I have literally identical problems like you desribed there, everything from TV not feeling smooth, monitor clarity and washed colours and blurry text, keyboard typing delay, not to mention mouse etc. etc., BUT in my case the PC works correctly at other location, I don't need to switch any part of the PC.
So, bad electricity clearly doesn't "destroy" your PC and monitor, as soon as you plug it into a clean electricity socket, it works pefectly fine.
Do you think running a NEW mouse on the laptops BATTERY power will fix my issues? My old mouse doesn’t work on the laptop even with battery mode, but everything on the laptop works perfectly perfectly fine otherwise. Games are smooth, internet connection is solid etc.
Post
by Slender » 13 May 2026, 02:25
jterri wrote: ↑13 May 2026, 00:11
any 3395 wireless mouse, but not on BULLSHIT NORDIC.
vxe r1 best variant.
jterri
Post
by jterri » 13 May 2026, 10:16
Slender wrote: ↑13 May 2026, 02:25
Oh okay, i was gonna try it today but i have to take my car to the car wash, so i’ll try everything in 2 days. I forgot to mention that my old mouse did get exposed to dirty electricity via the charger. The new mouse that i will use will ONLY be running on the laptops battery, not the power coming from the wall via the charger.
dermodemon
Post
by dermodemon » 13 May 2026, 11:25
i thought vxe r1 based on Nordic 52840?
mchose g3 ultra - realtek mcu. works best in wireless mode for me. sad that i can't use this shape
Post
by Slender » 13 May 2026, 12:14
dermodemon wrote: ↑13 May 2026, 11:25
no, regular r1 based on non-nordic mcu controller, and im test r1 and r1 pro, r1 super stable polling rate without drop to 500hz and feel like it connected by wire.
avoid 3311 clones like 3395 se. ONLY 3370 OR 3395.
dermodemon
Post
by dermodemon » 13 May 2026, 12:39
Slender wrote: ↑13 May 2026, 12:14
- 7.png (4.63 KiB) Viewed 3471 times
jterri
Post
by jterri » 13 May 2026, 13:40
![Image]()
Did the mouse movement ever get better for you after switching to a wireless mouse or any kind of wireless system that was not connected to the grid?
Post
by Slender » 13 May 2026, 20:35
jterri wrote: ↑13 May 2026, 13:40
![Image]()
no. it is same if no polling rate issues caused by wireless mcu.
U need know 1 thing. Battery mode / socet is same, if we talk about that weird problem.
Post
by Slender » 13 May 2026, 20:45
dermodemon wrote: ↑13 May 2026, 12:39
I opened this mouse two years ago, and I can say with certainty that it's definitely not Nordic. It's probably a new revision. I ordered a new R1, I'll open it up and check. By the way, I ordered a VT7 Gen2 with a new Nordic MCU. I wonder if the issues have been fixed?
jterri
Post
by jterri » 13 May 2026, 22:31
Slender wrote: ↑13 May 2026, 20:35
![Image]()
Oh okay. Were you ever able to fix your electricity input lag issues at all or are you still having problems?
