I have a real electricity problem
Assticker
Re: I have a real electricity problem
Post by Assticker » 26 Jun 2026, 08:03
astroasis wrote: ↑
25 Jun 2026, 17:22
Assticker wrote: ↑
25 Jun 2026, 16:41
astroasis wrote: ↑
25 Jun 2026, 16:15
Have you tried using your pc and monitor on sockets at the opposite direction of your house/apartment?
nope never, should i ?
EDIT: did remember that i already changed the whole floor and its the same issue ...
I just remember in my old house when i moved my pc from north side sockets to south side it improved, im in a new house now where everythings fine though, it is a hard issue to find and fix if you cant move
like i said in a earlier post, im just gonna ground my pc outlet, not the full house, since my pc in a room with a balcony
unexpected8
Post by unexpected8 » 26 Jun 2026, 08:41
I tried grounding the computer with a fresh ground connection, and the problem disappeared, then returned. Strangely, I also tried connecting the computer to a separate power source, namely solar power, and the problem persisted
Assticker
Post by Assticker » 26 Jun 2026, 10:59
unexpected8 wrote: ↑
26 Jun 2026, 08:41
check the installation, put the router in the same grounded outlet...etc
you can know whats the issue... just proceed by elimination.
idont know where u live, but u can check about power delivery in your country, building ...etc
unexpected8
Post by unexpected8 » 27 Jun 2026, 04:05
The monitor, computer case, and router are connected to solar power, but the problem persists. The issue only disappears late at night or when any metal objects are connected to the case with a wire, and then it returns after fifteen minutes or more, or less. I even tried connecting the device to the air conditioner's power line, since it's a separate line, after disconnecting all the circuit breakers, but the problem remained. Believe me, this is a difficult problem to pinpoint, and it might vary from person to person. I live in the Middle East, which means the problem is widespread.
Honestly, when the problem is on, anyone can kill me in PUBG. When the problem is gone, all shots are recorded, and even the screen color is better and clearer. It's even faster when opening the Ads lens.
Assticker
Post by Assticker » 27 Jun 2026, 14:11
27 Jun 2026, 04:05
hmmm middle east ? i live in algeria
did u take ur computer to test in another place? are you alone with this issue?>
1nputlag34
Post by 1nputlag34 » 27 Jun 2026, 15:14
Assticker wrote: ↑
27 Jun 2026, 14:11
27 Jun 2026, 04:05
tu parle fr ? envoie ton discord
unexpected8
Post by unexpected8 » 27 Jun 2026, 23:19
I speak Arabic.
Yes, I tried the device in three different homes, and the problem persists.
I only remember that in winter, the performance improved for four days without any intervention from me, then the problem returned.
Yazeedtt
Post by Yazeedtt » 30 Jun 2026, 22:20
27 Jun 2026, 23:19
I speak Arabic.
Finally, I found someone who speaks Arabic and is dealing with the same problem. I’m in exactly the same situation. I’ve tested my PC in more than one house, but the issue is still there. In some places, the problem seems to be about 50% less severe, but it’s clear that the PC has become practically unusable, even in new locations.
If you’d like, send me a DM so we can discuss it further.
Assticker
Post by Assticker » 04 Jul 2026, 12:59
guys im about to ground 2 outlets, one for my router room, and one for my pc room, next week...
im gonna update the thread in case it can help some1 here.
unexpected8
Post by unexpected8 » 05 Jul 2026, 01:14
I'm also experiencing the same problem. The strange thing is, I connected the computer and router to a UPS and solar power supply, and the problem improved for about an hour before returning.
(Note: The solar power supply was not grounded or had any grounding wires. I don't know if that's the cause or not.)
