MK92 wrote: β07 Jun 2026, 08:09
adrian_13371 wrote: β07 Jun 2026, 07:23
MK92 wrote: β07 Jun 2026, 06:15
adrian_13371 wrote: β07 Jun 2026, 04:31
Until you guys can actually measure and capture the "PC working bad" because of "dirty" electricity to me it's all schizo posting and placebo. There is literally zero videos/benchmark that show the difference between how pc works on "clean" vs "dirty" electricity
Lol, the UI animations in windows, browser, anywhere loading slowly and choppy like the refresh rate on the desktop is actually below 50, websites loading slower (NOT an internet speed issue, but processing of the CPU), mouse leaving trails behind and being delayed (moving mouse left and right at moderate speed provides like 5 cursors at the same time on the screen, because refreshing and frametime pacing is so low). And among many examples, if you put 3 icons on the desktop, one above each other, and you try to move cursor above all of them up and down fastly, the one in the middle won't even be "registered" - i.e. it won't be highlighted like it should, it simply skip this input and goes to the next icon.
Not to mention clearly degraded visuals like blury text, washed colours, brigthness of the monitor clearly being lower than it should be and is "wobbling" and "breathing" etc., you don't need to measure something that can be felt by using the PC for literally 10 seconds that everything is off, from refresh rate, output delays and desync between picture, sound and inputs, frametime pacing is broken, typing is dealyed, mouse is delayed, everything is delayed because of error-correcting protocol that triggers when there are power issues.
And I have a measures - the neutral drift between L and N+E was 6V and even higher right after I turned off appliances, while now when the PC works perfectly it's below 2V.
This is what actual power issues does to a PC, while people which are "behind the server", "hitbox is not correct", "enemies see me first" and stuff like that, yeah they are probably schizos, since this is done server-side and cannot be caused by electricity.
All of these issues listed and yet nobody has ever caught that on camera? Why? because there is no such thing, electricity has no effect on your monitor quality/refresh rate or the speed of your pc, its impossible. Unless you can prove me wrong
Sure, electricity is just an ON/OFF binary state, it either work and power up the PC, or it doesn't...my ass...if you have no idea how a broken neutral reference, neutral potential, polarity problems, high impedance, voltage sags and fluctuations, neutral drift, ground loops, harmonics, or just simple stuff like corroded and loose connectors etc. etc. could interact with sophisticated and sensitive devices like modern PCs, then you better don't say anything...this is like saying that tyres on a car have no impact on car's performance or some crap like that.
Power issues are causing 90% of problems for people in this forum, its just that someone has minor electrical issues (= minor symptoms), and some of us had huge faults in installation (= major symptoms, and almost non-usable PC). If the PSU's active PFC cannot regulate power correctly anymore because the electricity is bad, then 3.3V, 5v and 12V internal rails collapse, ripple increases, transient response became shit, and you have those symptoms.
Finally somebody who has a "real" understanding of what is causing all this weird symptoms.
It was decided yesterday at the owners' meeting that all electricity meters in the basement must be enclosed.
On this occasion, the entire electrical installation is also supposed to be modernized.
Currently, we have a TNC-C system which is now almost 60 years old.
And itβs anything but suitable for modern electronics, especially high-performance PCs.
Iβm 99% sure this problem will be solved once the construction work is finished.
For anyone interested in what a TNC-C system is, you can google it. ...
Feel free to add me in discord: akaza3
