EMI/floaty mouse
Mo_init
EMI/floaty mouse
Can anyone help me with this issue or any information that could help me test stuff to figure more in depth fixes? I tried most things.
Discord: aykoo_init
Instagram: mo_initval
Thanks.
Discord: aykoo_init
Thanks.
astroasis
Re: EMI/floaty mouse
Uhh bro there is no fix, had it a decade
MK92
There is a fix, one of those two:
1) rewire entire apartment/house fully with everything new, from fuse box to sockets and switches and junctions and new grounding rods and neutral bars and new lights, along with fresh TN-S wiring
2) if this doesn't help, then the problem is not just your apartment but its building-level problem or bad grid from the substation, so you need to move places until you find a place that isnt affected by shitty electricity.
Sadly nothing else can be done than just one of those two, don't listen to schizos which are blaming your body and other supernatural stuff, its 99.9% electricity problem, it isn't easily diagnosed because there are many possible electrical problems that each cause same set of symptoms, and short of full rewiring or moving out there isn't any easy fixes really.
ablemor
Cant you see how many existing threads there are? You're just spamming the forum by creating a useless topic when there's already plenty of info on this. Besides, we have no idea about your experience, so you might not even be facing this specific issue.
Desync4life
MK92 wrote: β22 Aug 2026, 13:56There is a fix, one of those two:
MK92
I already fixed it by fixing bad neutral with oxidized connectors and shared circuits, but you can keep on wiping your hands in your shirt for another 10 years like you said in another thread because you are among those shizos who think that its your sweaty hands causing this, fully delusional no wonder none of you can fix your problems if you jump to such a stupid things instead of simply hiring an electrician to measure impedance and voltage drift, possible potential imbalance as well, and fix itDesync4life wrote: β22 Aug 2026, 14:09MK92 wrote: β22 Aug 2026, 13:56There is a fix, one of those two:
Sadly nothing else can be done than just one of those two, don't listen to schizos which are blaming your body and other supernatural stuff, its 99.9% electricity problem, it isn't easily diagnosed because there are many possible electrical problems that each cause same set of symptoms, and short of full rewiring or moving out there isn't any easy fixes really.enjoy spending all that money for nothing. Itβs not electricity
astroasis
Either you're lying or the UKs grid is totally messed up because I've tried multiple locations including new and old houses which absolutely didn't need any rewiring doneMK92 wrote: β22 Aug 2026, 14:42I already fixed it by fixing bad neutral with oxidized connectors and shared circuits, but you can keep on wiping your hands in your shirt for another 10 years like you said in another thread because you are among those shizos who think that its your sweaty hands causing this, fully delusional no wonder none of you can fix your problems if you jump to such a stupid things instead of simply hiring an electrician to measure impedance and voltage drift, possible potential imbalance as well, and fix itDesync4life wrote: β22 Aug 2026, 14:09MK92 wrote: β22 Aug 2026, 13:56There is a fix, one of those two:
MK92
You said in another thread that you moved only 1 km away which is basically identical street grid, if you move then move to some remote area outside the city where only a few houses would be connected to the local substation grid, and not entire neighbourhood full of apartment blocks
Desync4life
Bro fixed it but still wants to come to blurbusters every day for what?
βSimply hiring an electricianβ Iβve seen multiple people here do that and spend thousands. NO FIX
If i fixed this problem id never ever in my life come back here and read any nonsense
but yea u fixed it totally
Mo_init
Things I've already tried:
Multiple different mice
Using the mouse both wired and wireless
Different USB ports
Different PCs
A PCIe USB expansion card
Fresh Windows installs
Reinstalling/removing GPU drivers and trying different driver versions
Different monitors, including an older 75Hz monitor
Different display connections/cables ( Will soon)
Testing with my RTX 2070 installed and removed
Using motherboard/GPU DisplayPort without the RTX 2070
Different PC hardware including motherboard, CPU, RAM, storage and PSU
Running LatencyMon and checking for DPC/interrupt latency issues
Testing with OBS and Replay Buffer both running and completely closed
One of the most interesting things is that I tested a completely different PC in the same room/house, using the same monitor and display cable, GPU and the mouse still had the same floaty feeling.
However, when I went to a friend's house and used my own mouse on their PC and monitor, it felt completely normal.
So far, the pattern seems to be:
At my house:
Different PCs + different hardware + multiple mice = floaty mouse feeling.
At my friend's house:
My same mouse + their PC/monitor = normal.
Because of this, I'm wondering if the issue could be related to something environmental, electrical, grounding, EMI/RFI, or another factor in my house. I haven't yet taken my own PC to another house to test it, which is probably my next major test.
Different USB ports
Different PCs
At my house:
