My setup:
- 360hz monitor, 240 fps (RTX 3070 with Ryzen 7 5800x)
- playing with PS5 controller on PC (Scuf Reflex)
- controller overclocked to 2000 (tried lowering to 1000 and it didn't help)
I've been experiencing this issue for a while now and am looking for any type of solution. Here's the best way to describe it:
It feels as though I don't have a true deadzone and can't build muscle memory as a result; I'm unable to make the smallest movements as my crosshair will just jump and shoot way past where I intend on aiming. No matter how much I've lowered my controller sensitivity or increased my deadzone, the issue has stayed. I've tried new controllers, but that hasn't helped either. My right stick movements seem to be too loose/imprecise/inconsistent (which I also experienced in other games like BO3 Zombies). Because of this, I'm unable to build muscle memory as my crosshair lands on a different area each time, undershooting or overshooting, even if I'm moving my stick by the same amount.
I've noticed when I change ANY in-game Fortnite setting, there's a NOTICEABLE effect on how my aim feels. Changing brightness, volume, region, reticle, mouse x and y speed, controller binds... all bleed into how my aim and sensitivity feel.
The slightest changes to my monitor OSD settings affect my sens (like bumping brightness up or down by 1%, increasing sharpness etc).
I re-calibrated my controller with Dualshock Calibration GUI. It felt like I was playing on 0 deadzone before, but is a bit better after recalibrating (currently on ~8.4% circularity).
Also any change to my computer peripherals affects my in game sens: a new display port cable, plugging pc into a different outlet/surge protector, different ethernet cable, new psu... all of these affected how my aim feels. Some of these "temporarily fixed" my issue, and my aim felt controlled, precise, like it actually followed where I was aiming, but it only lasted for about 10 minutes before the issue returned. Swapping the PSU made the most noticeable change and it felt like my issue was resolved, but things went bad again about 20 minutes later. This has led me to believe that some electrical issue is the main culprit (either within the PC or my home's grounding) --> EMI / RFI problem.
Overall it feels like my crosshair doesn't follow where I'm aiming with my right stick. The movement is inconsistent, shaky and I'm unable to truly aim as a result. It's as though there's something that's interfering with how my controller inputs are registered to my PC, leading to the issues with aim detailed above.
Has anyone experienced this? Looking for any type of solution.
Issue with Aim and Inconsistent inputs (EMI / RFI ?)
Realistic9088
SweatHatesMe?
Re: Issue with Aim and Inconsistent inputs (EMI / RFI ?)
Im experiencing the same issues as you, and with temp fixes like yours that works for seconds. Have you ever played with a different setup and on a different place and felt the same issue?
Currently there's no fix to this unless is EMI/RFI related, but is hella expensive lol.
Templar_Warden
Realistic9088 wrote: β01 Sep 2026, 21:27My setup:
Hm, I dont expereince some of these. I dont know if you want, i can link my youtube vids here or if you just wanna look up my username on yt you can. but for me it almost feels like the opposite of what your describing. its like im aiming at a ghost of the enemy from the past, like its always behind where im actually trying to aim. and my inputs are moving and distance lesser to what im actually aiming at. so im not doing any of this over aiming stuff. it does feel like the micro movements are not as precise though with my issue.
