Constant Voltage Transformer (CVT)/Isolation Transformer
stella
I used Medical Isolation Transformer and it made no change in performance. Is there anyone who tried Constant Voltage Transformer. IDK if its low order frequency we are dealing with. CVT, Line reactor, Active Harmonic filter etc... deals with 100hz to 500hz. I read a forum that said design a LC filter just to eliminate 150hz frequency from the powerline. But its hard to make a LC on our own, could be left to the professionals hand. Active Harmonic filter from Schneider Electric costs a fortune and also I think they only use it for Data centers, Medical use and Big companies. Im planning to try the CVT cuz im suspecting the motor actions are the ones making the power line worse. The only thing I dont understand is why is the issue goes away when we remove or alter the N-PE bonding. Once the reference is changed the problem disappears for a couple of minutes. High frequency noises in the RC are not bleeding out (energy can only be transformed). The RC is not heating up so I don't think the noise is bleeding into heat nor parasitic capacitance. Tried battery + Inverter setup but I think inverter is also a culprit, the problem stays still with zero difference. IDK how the both grid and inverter can give same results. So if anyone tried CVT let me know how it went. I think i seen someone taking about CVT but never shared the results, he said it can throw 160hz frequency from its own to the computer. Thank you!
pervysage19
Re: Constant Voltage Transformer (CVT)/Isolation Transformer
Which model did you try?
And what did you plug into it?
And where are other devices connected to your computer plugged into (such as internet modem, speakers, monitors, etc?)
stella
This is a Medical Iso transformer. https://www.miracle.net.in/medical-isol ... ansformer/
MEDICAL ISOLATION TRANSFORMER,MIT 1000,1000VA,1000W
I have a APC Back-UPS 1100 VA. Only my PC and Monitor plugged into it. I even tried directly to it with IEC Female to Female.
Router is directly connected to a 12V battery no AC to DC conversion. Directly to the battery. And it runs on battery.
No other external devices connected no speakers. Logitech G102 mouse and Ducky One 2 mini Keyboard. Moondrop Chu IEM.
Even tried wireless Gpro, Razer Orochi V2. No changes, after a couple of minutes the lag came back.
Either my ISO transformer is not great or its not gonna solve the issue.
- Medical.PNG (75.39 KiB) Viewed 596 times
stella
One more thing I need to mention, The router LED's are really bright when Im running them through the 12V battery. When I was using them in 230V, the LED's don't appear this bright. Most of the LED lights like bathroom light, and LED tube lights don't blink that bright. AC voltage shows its 230 to 240 everytime, no noticeable voltage drops.
pervysage19
How does your router get internet from the wall? Coax cable, fiber optic?stella wrote: β26 Sep 2026, 09:21One more thing I need to mention, The router LED's are really bright when Im running them through the 12V battery. When I was using them in 230V, the LED's don't appear this bright. Most of the LED lights like bathroom light, and LED tube lights don't blink that bright. AC voltage shows its 230 to 240 everytime, no noticeable voltage drops.
stella
pervysage19
Only other thing I can think of is to keep the Isolation Transformer a good distance away from your PC because it will affect nearby power supplies with magnetic leakage.
lila
Do not use these devices; they are ineffective.Please use a shielding box.https://item.jd.com/10107254623605.html
