Fixed the desync/input lag issue.
MontyTheAverage
Re: Fixed the desync/input lag issue.
Every time I see a new post with title like this thinking hmm maybe there is something new I can try out to see if it works or excited to see someone possibly fix it and it's just this guy posting again
codetechceo
That actually helped a lot the image became cleaner during motion, and even 60 fps looks smoother. still stable for 2 days
- naporitan
I recommend setting these settings for CS2
Babluga
Before performing the fix, you need to clear your mind and let go of all your mental hang-ups and beliefs.
Let me say right off the bat that the claim about electricity and EMI is a lie.
I have an ungrounded outlet and aluminum wiring from the 90s, and I haven't had any problems.
I finally solved the desync and input lag issue.
This is HILARIOUS...
- RealNC
Deleted some posts involving cursedgamer12's posts (warning issued) and replies to them (to clean up the thread.)
Please keep it civil.
codetechceo
3 days pc still stable, it smoother than ever, before all that i had 3 different setup and laptop with same problems, now its all gone , thanks
PotentJW
I didn’t follow this guide, but few weeks ago reset bios to default and just enabled XMP, it’s been working like a charm ever since. Maybe we’ve convoluted our perception by touching so many levers over the years. Sadly I don’t have a CPU direct port (Intel). I also found a lot of success with network jitter by installing the Realtek Ethernet driver directly from Realtek’s website (the one without power saving features).
cursedgamer12
Shade7
So what exactly did you do?codetechceo wrote: ↑28 Sep 2026, 07:163 days pc still stable, it smoother than ever, before all that i had 3 different setup and laptop with same problems, now its all gone , thanks
Configure Secure boot the way he recommended?
Use default RAM speeds (XMP/DOCP OFF)?
All of the above?
