Having an argument with my son and we can't see eye to eye so I suggested to him that I join this forum to ask the experts. I'm sure there will be plenty of other things I can learn here too.
Here is the conundrum. Is it possible for a laptop screen (or computer LCD monitor e.g. HP L1910) which has a different refresh rate to the frame rate of a video it is displaying, to show two frames at once or partially if you happen to pause at the right time? I think it is possible. I don't think it would happen often but it could happen. He disagrees and says it's impossible.
New Member - Two frames/partial frames
- RealNC
Re: New Member - Two frames/partial frames
If you disable vsync, sure. And not only two frames. There can be multiple frames. On a 60Hz screen with a game running at 600FPS with vsync OFF for example, there's 10 frames at once on the screen. But it won't be visible when you pause, because there needs to be motion to be able to tell. Otherwise all frames are the same. During motion, tearing is the observable effect of multiple frames on the screen. In the 600FPS@60Hz example, there's gonna be 9 tear lines.Stokerup wrote: ↑26 Sep 2026, 10:40Here is the conundrum. Is it possible for a laptop screen (or computer LCD monitor e.g. HP L1910) which has a different refresh rate to the frame rate of a video it is displaying, to show two frames at once or partially if you happen to pause at the right time? I think it is possible. I don't think it would happen often but it could happen. He disagrees and says it's impossible.
Another way to obeserve multiple frames without motion would be a strobe pattern, where each frame has different color. One frame is fullscreen white for example, the next fullscreen red, then blue, etc. With vsync off and 600FPS@60Hz you'd never see the whole screen having the same color, but there would be 10 colors at once, each separated by a horizontal line.
Edit:
I forgot to mention that because LCDs and OLEDs are sample-and-hold displays, there's always at least two frames visible at the same time, even when vsync is eanbled. When the display starts scanning out a new frame, the previous frame is still on the screen and being "drawn over" by the new frame from top to bottom.
Dalek
Yes, this is called frame pacing. If you have an odd refresh rate (like 360hz) that doesn't correctly divide to a video's frame rate, you will see multiple frames appear. This is fixed with VRR being used in a player or switching to a refresh rate that divides properly.
This post goes into detail: viewtopic.php?p=95888#p95888
Stokerup
Thanks for that answer. BTW we were not running a game. We were watching a Facebook Video Reel.RealNC wrote: ↑27 Sep 2026, 08:12If you disable vsync, sure. And not only two frames. There can be multiple frames. On a 60Hz screen with a game running at 600FPS with vsync OFF for example, there's 10 frames at once on the screen. But it won't be visible when you pause, because there needs to be motion to be able to tell. Otherwise all frames are the same. During motion, tearing is the observable effect of multiple frames on the screen. In the 600FPS@60Hz example, there's gonna be 9 tear lines.Stokerup wrote: ↑26 Sep 2026, 10:40Here is the conundrum. Is it possible for a laptop screen (or computer LCD monitor e.g. HP L1910) which has a different refresh rate to the frame rate of a video it is displaying, to show two frames at once or partially if you happen to pause at the right time? I think it is possible. I don't think it would happen often but it could happen. He disagrees and says it's impossible.
Edit:
Stokerup
Thanks.Dalek wrote: ↑27 Sep 2026, 08:40Yes, this is called frame pacing. If you have an odd refresh rate (like 360hz) that doesn't correctly divide to a video's frame rate, you will see multiple frames appear. This is fixed with VRR being used in a player or switching to a refresh rate that divides properly.
BTW if it makes any difference, here is my specs.
Device Name DESKTOP-FINEO1T
Processor Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz 3.30 GHz
Installed RAM 8.00 GB
Storage 119 GB SSD SAMSUNG SSD SM841N 2.5 7mm 128GB
Graphics Card Intel(R) HD Graphics 4600 (113 MB)
Device ID 049A0FEC-3572-4434-8E1F-46C21C386423
Product ID 00330-80000-00000-AA024
System Type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
