Complete first five steps. Thats itShade7 wrote: ↑Yesterday, 13:43So what exactly did you do?codetechceo wrote: ↑Yesterday, 07:163 days pc still stable, it smoother than ever, before all that i had 3 different setup and laptop with same problems, now its all gone , thanks
Configure Secure boot the way he recommended?
Use default RAM speeds (XMP/DOCP OFF)?
All of the above?
Fixed the desync/input lag issue.
codetechceo
Re: Fixed the desync/input lag issue.
Shade7
What do you think (out of those five steps) was likely to make the most significant difference in your case?codetechceo wrote: ↑Yesterday, 16:42Complete first five steps. Thats itShade7 wrote: ↑Yesterday, 13:43So what exactly did you do?codetechceo wrote: ↑Yesterday, 07:163 days pc still stable, it smoother than ever, before all that i had 3 different setup and laptop with same problems, now its all gone , thanks
All of the above?
codetechceo
i think secure boot settings before installation and driver installation orderShade7 wrote: ↑Yesterday, 20:23What do you think (out of those five steps) was likely to make the most significant difference in your case?codetechceo wrote: ↑Yesterday, 16:42Complete first five steps. Thats itShade7 wrote: ↑Yesterday, 13:43So what exactly did you do?codetechceo wrote: ↑Yesterday, 07:163 days pc still stable, it smoother than ever, before all that i had 3 different setup and laptop with same problems, now its all gone , thanks
All of the above?
cursedgamer12
it will all come back eventually. if you have the existing ghost lag problem, there is no getting rid of it Period
