Everything about latency. This section is mainly user/consumer discussion. (Peer-reviewed scientific discussion should go in Laboratory section). Tips, mouse lag, display lag, game engine lag, network lag, whole input lag chain, VSYNC OFF vs VSYNC ON, and more!
Input Lag Articles on Blur Busters.
escape
Post
by escape » 30 Sep 2026, 21:22
naporitan wrote: ↑29 Sep 2026, 23:17
A bit of information about overclocking RAM: when you overclock RAM, you are guaranteed to get error correction, and the more you overclock, the more error corrections you get.
When you buy RAM, you get a guaranteed stable JEDEC profile, and if you go beyond this profile, you get error correction. For this reason, you won’t see any errors in stress tests. Error correction can occur on the FCLK side and also on the RAM side itself, since DDR5 has On Die ECC technology — this is a memory error‑correction technology built into each DDR5 standard chip.
When overclocking RAM, there is no error correction level indicator, but if you use the JEDEC profile, you get 0% error correction.
An interesting development at the time of the Ryzen 7000 launch was the following official announcements:
AMD confirmed that the Ryzen 7000 series of processors officially supports DDR5-5200 memory for single-rank and dual-rank configurations with one DIMM per channel. When using two DIMMs per channel, the officially supported speed drops to 3,600 MT/s.
for my experience jedec feels better for input but xmp also helps %1 lows. my default ram speed is 4800, does this mean I can go up to 5200 without ECC ?
qbBA
Post
by qbBA » Yesterday, 01:25
RealNC wrote: ↑30 Sep 2026, 08:32
qbBA wrote: ↑30 Sep 2026, 01:50
When are you going to ban that kid?
No one is forcing you to read his thread/
Let's see how long it takes before you ban Seruna yourself.
naporitan
Post
by naporitan » Yesterday, 04:58
escape wrote: ↑30 Sep 2026, 21:22
No, for that you need to purchase RAM that already has a native JEDEC profile at 5200 MHz.
