desync curse
tattoo
desync curse
Post by tattoo » 29 Oct 2026, 12:08
"Hi, so like most users here, I'm dealing with a desync curse issue or whatever the hell it is,and I've been dealing with it for over 10+ years now. I've changed locations, tried laptops, and tried different types of CPUs, GPUs, and motherboards. I've even paid for optimizations, optical cables, power stabilizers, EMI filters, fast OLED monitors, and 15 different types of mice.
Like most people here, some tweaks work and some don't, but they only work for a short period. As a last resort, I am installing a full solar panel system and a 16kW power unit! It should be done in about 25–30 days per the contract, and I'll keep you guys informed! If that doesn't work, I'm just going to f quit!"
Also what worked best for me so far "cs2" clean windows instal,only steam and faceit-anticheat,and do not open nvidia control pannel,do not touch scaling/full screen mode/gpu rendering nothing! as soon as i do that all goes downhill,the problem is still there but manageble!
nickchraj
Re: desync curse
Post by nickchraj » 29 Oct 2026, 13:12
There is no such thing as permanent desync, you will only get desync if your connection is trash. what's permanent is the floaty mouse issue and it has nothing to do with desync, is that what are you referring to?
unexpected8
Re: desync curse
Post by unexpected8 » 29 Oct 2026, 14:12
I don’t want to discourage you, but I tried this with solar panels and it didn’t solve the problem—perhaps because it wasn’t connected to a ground (earthing) system.
ablemor
Re: desync curse
Post by ablemor » 29 Oct 2026, 14:27
time wasting and money
naporitan
Re: desync curse
Post by naporitan » Yesterday, 02:01
tattoo wrote: ↑
29 Oct 2026, 12:08
I have the same thing
I recently purchased an AMD graphics card, and when Secure Boot is set to "Standard" mode, the AMD Anti-Lag option is not available in-game.
When Secure Boot is in Standard mode, I encounter strange bugs in the system.
To fix this bug, you need to set the Secure Boot option to "Custom" mode and clear the default keys before installing Windows.
And after that, I get AMD Anti-Lag 2.0 in the game settings, with no driver-related bugs in the system.
https://www.asus.com/us/support/faq/1050047/
https://www.gigabyte.com/Support/Consumer/Faq/4395
https://www.asrock.com/support/faq.asp?id=531
I’d also like to mention something regarding RAM: the memory controller inside your AMD or Intel processor needs to be stable. I know that many people run stress tests on their RAM and feel reassured when they see zero errors, but that is actually a misconception.
Users often overclock their RAM, but the specifications indicate that the memory controller is only guaranteed to operate at lower frequencies.
The thing is, when buying a mid‑range processor, we have a small chance of winning the silicon lottery, and the memory controller simply won’t be able to handle 2000 MHz FCLK, etc.
RAM has temperature hotspots, so your case needs to provide effective cooling.
The higher the temperature at hotspots within the RAM, the greater the number of error corrections.
The motherboard’s Memory QVL is not heresy.
https://www.gskill.com/configurator
https://youtu.be/Ft7ss7EXr4s
Don't buy Intel processors; Intel is not for competitive gamers.
Intel still does not support Gear 1 with DDR5.
The desync problem refers to poor compatibility between the RAM and the motherboard, as well as poor performance of the memory controller with the RAM.
Many people do not follow the QVL, and problems arise at this stage. But even if this stage is fixed, the most difficult issue emerges — the memory controller in the processor, and that’s really a silicon lottery.
Choose esports monitors: by purchasing one, you gain all the advantages and a great experience when playing competitive games.
For example, when you purchase an XL2566X+, you get a monitor with a built-in processor that supports custom resolutions; since the processing takes place directly within the device itself, this ensures minimal latency and sharp clarity during fast-paced, dynamic scenes.
1728x1080 for PUBG
1280x960 for CS2
Screenshot_20261028_214845_Samsung Notes.jpg (353.65 KiB) Viewed 590 times
It is better to avoid monitors with DSC technology.
simon
Re: desync curse
Post by simon » Yesterday, 04:02
Alright. Thanks, mr. salesman.
It's like suggesting the average joe sixpack to buy a ferrari and usain bolt running shoes.
Nothing to do with solving the issue.
naporitan
Re: desync curse
Post by naporitan » Yesterday, 04:53
simon wrote: ↑
Yesterday, 04:02
You’re thinking too superficially, so you can’t understand the message.
playa
Re: desync curse
Post by playa » Yesterday, 08:12
The message is clear - Nobody in this forum knows anything about the issue. And i doubt that the people who do will come here to discuss alongside this fishhead
astroasis
Re: desync curse
Post by astroasis » Yesterday, 08:15
Heres something funny, power bank at first felt great and normal, now one week later the blurry monitor is returning lol, hit reg and input lag are slightly better
escape
Re: desync curse
Post by escape » Yesterday, 20:07
naporitan wrote: ↑
Yesterday, 02:01
tattoo wrote: ↑
29 Oct 2026, 12:08
1728x1080 for PUBG
1280x960 for CS2
so are you saying use display scaling ? I have the exact monitor and play 1728x1080
