I have been using the XG248QSG nearly a year, but I'm still struggling to figure out the best/better settings on it.
Is it the best to have elmb on or use the variable od or something else?
I mainly play Valorant and Apex, anyone who has the same monitor could share their settings?
tweaked settings on the ASUS XG248QSG Ace?
- kyube
Re: tweaked settings on the ASUS XG248QSG Ace?
I'd run ELMB-Sync on this panel if I were you.yjyj43 wrote: ↑09 Nov 2026, 08:48I have been using the XG248QSG nearly a year, but I'm still struggling to figure out the best/better settings on it.
This way, you eliminate these concerns simultaneously:
• Tearing,
• Juddering,
• (Eye-tracked) motion blur
It's especially important in games such as Apex, which have a frame rate limit of 300FPS, where your only 2 options to achieve a competitive advantage are either using frame interpolation or backlight strobing or solving spatiotemporal effects (juddering, tearing or other stutter concerns)
For Valorant, you're likely fine using the typical GSYNC+VSYNC+Reflex setup, which you'd also be using in Apex.
As a side-note, if you have time & are willing to contribute data of your panel, consider doing this test of ELMB-SYNC in you free-time.
I'd greatly appreciate it the data you'd provide, as one can rarely find users of 610Hz TN's online.
yjyj43
Thanks for helping me out, I'd love to test them out soon in my free time!
