BenQ XL2411P screen overclock
Luci05
Post by Luci05 » 18 Jan 2026, 01:36
Hello, how are you?
I have been reading several topics about monitor overclocking, specifically for the **BenQ Zowie XL2411P**, and I found a lot of different information.
I made some attempts, but they did not work as expected. I managed to set the monitor to **200Hz** using some configurations from this thread:
viewtopic.php?t=8435
The monitor displays an image, but it appears **out of scale or incomplete**, as if the signal is not properly synchronized or as if the cable is disconnected. I used some applications like OORBuster.exe, but it was the same result.
In short, I am here to ask for your help to achieve a **working and stable overclock** on this monitor.
Any guidance, timing suggestions, or step-by-step instructions would be greatly appreciated.
I saw that in some topics the monitor's FW version is mentioned.
Luci05
Re: BenQ XL2411P screen overclock
Post by Luci05 » 18 Jan 2026, 14:30
Well, I ran some tests again at 200Hz, running OorBusterX64.exe, OorBuster.exe, and AntiOutOfRange, everything went fine, but I still keep getting the out of range message, and then the monitor goes black ... I left some photos; if anyone can help in any way, I would be grateful.
Out of rage.jpg (3.62 KiB) Viewed 16579 times
200hz ok with of rage.jpg (5.2 KiB) Viewed 16579 times
Luci05
Post by Luci05 » 19 Jan 2026, 14:04
Maxinator500 Thanks for the message.
I can’t reply to PMs yet due to forum restrictions, so I’m answering here. :(
I already have the V3 firmware, which I downloaded from your Git profile.
However, I have never done this kind of firmware flashing before.
Could you please explain the flashing process step by step (connection, OS, tools, and precautions)?
I want to make sure I do everything correctly and avoid any risk of bricking the monitor.
Thanks in advance.
Maxinator500
Post by Maxinator500 » 20 Jan 2026, 00:41
Luci05 wrote: ↑
19 Jan 2026, 14:04
No problem. Then I'll just send you my contact information.
Luci05 wrote: ↑
19 Jan 2026, 14:04
I will, but not here. All the necessary information is already laying around somewhere here on the forum, so I don't think it's a good idea to make another copypasta which gonna confuse you even more.
darrenfv
Post by darrenfv » Yesterday, 16:01
Hey Maxinator, i saw you contacted me on pm and offered some help. I really appreciate that but unfortunately i cant answer your pm for some reason. Would you mind sending me another pm with your contact info / discord so i can speak to you, thanks alot!
Post by Chief Blur Buster » Yesterday, 19:40
darrenfv wrote: ↑
Yesterday, 16:01
New forum members don't get PM priveleges until they have enough posts. The more posts you have, the more priveleges a forum member gains, including private messages.
This moderation queue is because most new members of a typical forum are spammers (And never get approved for their first post), basically posting advertisements as their first messages.
