MontyTheAverage wrote: ↑23 Nov 2026, 19:11
chipotlechicken wrote: ↑22 Nov 2026, 08:14
MK92 wrote: ↑10 Nov 2026, 04:21
Its 100% electricity issue, proven and fixed several times, but the mods just keep on moving useful threads to "niche issues" subforum where no one sees it because "no electricity threads here !1!" bullshit.
Impedance on your grounding/neutral is too high and then voltage drifts all over, and the resistance on your socket should be below 2 ohm...modern PCs are just (too) sensitive to electricity anomalies.
You're right it is electricity. But in my situation it was both. Basically I was fighting 2 battles, both my power quality as well as my network quality. Luckily my ISP is pretty competent so the infrastructure to my house is fine, and not the problem. Same with my energy company, the grid is pretty up to date and i have a nice new transformer that i walk by down the street of my house.
My issues stemmed from the things that were happening within my specific house.
Had to change my network gear, get a non poe switch, use the last port on it for the uplink, and then add my poe switch and access point after.
What did you do exactly with the network? I am not understanding.
Here's my full network stack which has me confident that my internet is not the issue. I am convinced that if any issues arise its probably electricity or a shitty monitor that marketing has convinced you is good, or like a defective Zowie (My second 2546k was dogwater and probably defective)
I have fiberoptics to my home, which comes out of a network panel in my garage. My ISP provides a modem/network access hub which the fiber connects to via SFP module. I believe im on XGS PON.
My plan is symmetrical 1GB up and down, and I am on a small business internet plan. I also added a static IP package, which is a REAL HARDCODED static IP, where they give you a gateway ip adress, subnet mask, all things that get programmed into your modems settings.
The technician came and programmed it into the modem, and it outputs on the 10Gb port on the modem. So from that 10Gb port I connect it to a keystock jack so it runs into my walls so i can have my router in my living room.
From the keystone jack in my living room I connect my TP link omada er605 router, and have the static ip settings on there. Then i connect lan port 2 on the router to the last port 8 on my SG2008 NON POE switch. I then use the closest ports 7 and 6 to connect to my PC, and the other to a SG2008P POE switch, on port 8. I then connect port 4 (the closest port that has POE) to my Wifi access point.
Basically my network stack didnt feel right with the wrong ports, and even in the switch manuals of tp link and ubiquiti you always want the uplink to be the last port. Then plug your devices in closest to that, so its basicaly backwards in order.
Also not having a regular NON POE switch felt wrong. I used to have the router to the POE switch, and since its half poe and half regular i thought it's fine. But i notice it feels better when you have a non poe switch. So router -> non poe switch -> poe switch -> wifi acess point.
PC connected to the non POE Switch
