Hello, looking for some help with my ViewSonic XG2431 (24-04 batch).
Gaming at 240Hz or 144Hz or any other resolution feels super jittery and unsmooth. Even with high FPS, it honestly feels like I’m playing on 60Hz—movement and aiming feel heavy, and spraying in-game feels laggy and totally out of sync.
One weird thing I noticed in CRU: the detailed resolution only shows 1920x1080 @ 60Hz, and there’s no DisplayPort block at all—just an HDMI block which has 1920x1080@239hz,1920x1080@144hz and 1280x960@60hz.
Right now, the only way I can get the game to feel little bit smooth and have my spray actually synced up to an extent is by adding a custom resolution (1280x960 @ 240Hz) in the CTA-861 block and also use SRE for GPU resolution, and then setting NVCP to GPU scaling with "No scaling." When I do this, the desktop shrinks to a square size window with horizontal and vertical black bars(reso in settings 1280x960@240hz) though monitor Osd reads 1920x1080@144hz .(there are 2 resolutions along side my custom resolution in ct block,1920x1080 @144hz and 1920x1080@240hz)
Here is what I’ve already tried with no luck:
VESA-certified DP cable
G-Sync + V-Sync + Reflex
CRU display scaling method
Clean Windows reinstall
Online UPS with a 1:1 isolation transformer
Any help is appreciated.
Edit 1: In ct861- 1920 x [email protected],[email protected] and [email protected] are present by default though when i select VTB-EXT from the TYPE dropdown menu I can see these 3 resolution there also. if I delete them from any one the 2 blocks , its gets deleted from both the blocks.
XG2431-Issue
qvik18
Re: XG2431-Issue
Chief or anybody please help? Is it a bad unit? Should i RMA?
qvik18
Re: XG2431-Issue
Another update: this monitor is not working with DP port of my mobo msi b550m pro vdh WIFI, as soon as I install amd display driver it doesn't responds with Amber light active on LED indicator, tried every possible solutions from my side and that msi support gave...
dp port of mobo is fine as other monitor is working fine and this monitor works with my 1660 and not with dp of mobo.
only HDMI port is working...
Registered for rma lets see how it goes
MY advise is to completely skip this so called ESPORT MONITOR...THANK YOU..
