Palmer Luckey's Quantum Ray Tube / Modern CRT / Probably LPD
millysoose
Post by millysoose » 30 Aug 2026, 01:35
Palmer Luckey: "I figured out a new way to make new CRTs. People have long said its impossible to do in low volume. I figured out a new way to build modern scanning ray tube displays. It's a bit of an novel one. It's not a pure CRT, but it will have identical visual characteristics. I call it a quantum ray tube".
Torin Herndon: "I am 100% sure Palmer will continue asking me to do it until it fully exists. We have materials and basic prototypes laying around the office, but we need to do a custom phosphor backed glass with a different chemical makeup than CRT phosphor glass so that it will be excited by a different wavelength of light. basically it is a long and horrible project, but we want to see a CRT like display with official VHS re-releases."
I can't post the sources because the forum blocks links to external domains for some reason (anti spam?) but it sounds interesting and if they pull it off they will go down in legends.
millysoose
Re: Palmer Luckey's Quantum Ray Tube / Modern CRT
Post by millysoose » Today, 03:35
More info from Palmer: [Regarding making new CRTs] It could be done if someone wanted to put a few hundred million dollars into it, but there are better ways to make modern displays that are visually identical - for example, using scanning lasers to stimulate RGB phosphors with the same rise and decay characteristics. I have some working prototypes, it can be done at a reasonable price even with low quantities, which this will always be.
I think the QRT is a LPD displayed made to imitate a CRT. To deepen my suspicions, the original LPD patent (US8232957B2) expires in about 1 month.
Cool enough Palmer.
But I wonder...
Will the the mask drawn by the laser, turning on and off as it sweeps? My guess: Yes it will.
Is "Quantum" hinting at quantum dots or is it just a marketing term? My guess: It's not marketing. Prysm mentioned Quantum dots as a possibility in patent 8233217 (Multilayered fluorescent screens for scanning beam display systems).
Baron of Sun
Re: Palmer Luckey's Quantum Ray Tube / Modern CRT / Probably LPD
Post by Baron of Sun » Today, 06:12
Could you tell how you can find his article / forum? I'm really interested in his idea.
millysoose
Post by millysoose » Today, 13:50
I collected these quotes from reddit and a youtube interview he gave. I wasn't able to post links because of the spam filter. You can find a lot of discussion about this on the ModRetro subreddit by searching "QRT".
