Trying to reproduce 0.4966ms timer resolution when requesting 0.5ms
Shade7
Post by Shade7 » Today, 18:16
I previously had my system returning a timer resolution of 0.4966ms when requesting 0.5ms, but haven't been able to recreate this since.
Specs:
  • Intel Core Ultra 7 270K Plus
  • MSI MAG Z890 Tomahawk WiFi
  • BIOS 1.AE0
  • Windows 11 LTSC 24H2 (26100.9974)
  • VBS/Hypervisor disabled
  • QPC frequency: 10 MHz
Originally, I had Dynamic Tick disabled and HPET enabled in Device Manager.
Between when I was getting 0.4966 and when I started getting 0.5000, the following happened:
  • Disabled and subsequently re-enabled HPET in Device Manager using PowerShell.
  • PC unexpectedly shut off due to a power outage. I then turned off the PSU switch, waited a bit, and turned it back on.
Not sure if the last two things are relevant, but figured I'd mention them.
I've since tried various BCD configurations, multiple restarts, System Restore, toggling HPET again, etc. with no luck.
Something interesting I found while testing through PowerShell:
  • Requested: 0.5000ms
  • NtSetTimerResolution returned: 0.4966ms
  • NtQueryTimerResolution shortly afterward: 0.5000ms
  • Finest supported resolution: 0.5000ms
This happens even while keeping the request active. Requesting 0.4966 directly doesn't seem to help either.
Does anyone have any idea what determines whether Windows returns 0.4966 or 0.5000 when requesting 0.5? Could disabling/re-enabling HPET or completely cutting power to the system have affected something?
My goal is to consistently reproduce the behavior where requesting 0.5000ms results in an actual, sustained timer resolution of 0.4966ms.
I know there are mixed opinions on whether 0.4966 is actually beneficial, and that's completely fair. I'm just more interested in understanding why this happens and how to reproduce it.
Would appreciate any ideas or suggestions on what else I could test. Thanks!
Asesino34
Re: Trying to reproduce 0.4966ms timer resolution when requesting 0.5ms
Post by Asesino34 » Today, 18:38
The only thing I know is that it depends on useplatformtick. If it's set to yes, it locks the timer to 0.5 ms, and it will never use decimal values. The timer also varies depending on the CPU and its value, or at least that's what I know
Shade7
Post by Shade7 » Today, 18:53
Asesino34 wrote: ↑
Today, 18:38
I only applied one tweak - Dynamic Tick disabled --> and got 0.496..
Afterwards tried disabling HPET in device manager, didn't like it, then re-enabled it --> but it never went back to 0.496 even with a system restore to right before i applied any timer related tweaks (and re-applying that initial tweak to disable dynamic tick).
I never touched useplatformtick (whatever it was alreayd set to, i left it as is).
Shade7
Post by Shade7 » Today, 19:03
Shade7 wrote: ↑
Today, 18:53
Asesino34 wrote: ↑
Today, 18:38
EDIT: disabled useplatform tick (was preivously unconfigured) --> still stuck on 0.5
Asesino34
Post by Asesino34 » Today, 21:06
Shade7 wrote: ↑
Today, 19:03
Shade7 wrote: ↑
Today, 18:53
Asesino34 wrote: ↑
Today, 18:38
That's very strange. Maybe your system has bugged out. The only way for the timer not to show decimal values is by having useplatformtick set to yes. I assume that when you said it was set to "Not configured", you meant that the value didn't exist in BCDedit, right?
As for system backups, they won't help if you've modified BCDedit. Even if you restore your system, BCDedit settings don't revert; they remain the same. System Restore only backs up files, not those settings. The only thing you can do is format Windows.
Personally, I don't touch disabledynamictick or useplatformtick. I have HPET disabled in both the BIOS and Windows, and my timer reads 0.499 ms. Every now and then I've seen it go slightly lower, but I've never really investigated why.
I know about the decimal values because I've spent many years experimenting with those three options
