monitor for PS4
alkaiser
monitor for PS4
Post by alkaiser » 26 Feb 2015, 17:44
hi
I want to get a monitor for my PlayStation 4
I would like one who have lowest input lag and good motion blur
as you know PS4 run 1080p max for games and 60fps max
would lightboost work with PS4? any benefit from freesync monitors?
please share with me your thoughts
DNAMouse
Re: monitor for PS4
Post by DNAMouse » 26 Feb 2015, 18:58
i think consoles do everything, i dont think you need a monitor to do all the work
fenderjaguar
Re: monitor for PS4
Post by fenderjaguar » 26 Feb 2015, 19:46
DNAMouse wrote:i think consoles do everything, i dont think you need a monitor to do all the work
He does want a low input lag 1ms monitor, but it doesn't need to be anything special.
http://forums.blurbusters.com/viewtopic.php?f=4&t=1922
mutantmagnet
Re: monitor for PS4
Post by mutantmagnet » 26 Feb 2015, 20:25
Besides the obvious gsync monitors you will want to consider this display by Benq, the RL2460ht
http://www.displaylag.com/benq-rl2460ht ... mi-output/
alkaiser
Re: monitor for PS4
Post by alkaiser » 27 Feb 2015, 05:44
thanks for feedback
Gsync work with PS4?
also the monitor mentioned says 10 ms delay
how come they always advertise 1 ms delay?!
fenderjaguar
Re: monitor for PS4
Post by fenderjaguar » 27 Feb 2015, 07:03
No, the gsync will not work with PS4. Only PC with nvidia kepler GPU +
Also, about the input lag, I think any 60hz display takes 16ms to scan a frame. Since if you divide 1 second by 60, you get 0.016 (that is the definition of 60hz, 60 cycles per second)
