lexlazootin
Post by lexlazootin » 10 Mar 2015, 08:04
wow... i'm so stupid. pretend i didn't say anything. :lol:
Edit: Well you could do 2 tests drawing squares with the mouse jumping 6 pixels to the right, 6 down, 6 left then 6 back up. then doing it again but 3 pixels to the right twice, 3 pixels down twice... and checking if they land on all the same corners of the last test.
that would test accel in every direction.
spacediver
Post by spacediver » 10 Mar 2015, 10:27
I don't think flood's test was measuring accel. It was meant to measure dropped samples.
flood
Post by flood » 10 Mar 2015, 17:56
http://www.overclock.net/t/1545382/csgo ... ps-samples
for every useful post on ocn there are 5 that just talk about how things feel subjectively
spacediver
Post by spacediver » 10 Mar 2015, 18:57
It'd be great to see a good double blind run.
flood
Post by flood » 12 Mar 2015, 00:15
welp
flood
Post by flood » 12 Mar 2015, 04:53
uhmm
me at ocn wrote: anyway i just did 10 runs switching between rawinput 0 and 1 kind of randomly, underclocked cpu+gpu, bots kicked from server so that fps is stable at 90. i did these consecutively, not alt-tabing or doing anything in between. fps remained stable except during the first run where it dropped to 70 for few seconds (maybe affected 5% of the data in that run)
raw data: https://docs.google.com/spreadsheets/d/ ... 1426052600
averages in microseconds
run1, m_rawinput 1:17976.021
run2, m_rawinput 0 :16401.25
run3, m_rawinput 0:16337.279
run4, m_rawinput 1:17818.37
run5, m_rawinput 1:17953.225
run6, m_rawinput 0:16269.625
run7, m_rawinput 1:17812.031
run8, m_rawinput 0:16421.492
run9, m_rawinput 0:16373.09
run10, m_rawinput 1:17959.365
m_rawinput 0 is consistently faster by 1.5ms
this is pretty solid evidence that m_rawinput 0 and m_rawinput 1 do not behave identically in terms of absolute responsiveness.
dmbr
Post by dmbr » 21 Mar 2015, 11:45
flood wrote:Image
welp
Would you mind interpreting the graph for my puny brain?
I'm quite interested in the lag differences between m_rawinput and RInput.
lexlazootin
Post by lexlazootin » 21 Mar 2015, 17:11
All the results in the graph are between 3000-6000 MICROseconds, which are 1,000,000th of a second. All the results being so close together shows that there pretty much no difference between any of the settings.
dmbr
Post by dmbr » 21 Mar 2015, 21:16
lexlazootin wrote:All the results in the graph are between 3000-6000 MICROseconds, which are 1,000,000th of a second. All the results being so close together shows that there pretty much no difference between any of the settings.
Thank you :)
Just to be clear, this is measuring input lag, yes?
lexlazootin
Post by lexlazootin » 21 Mar 2015, 22:59
yes
