New HBM AMD GPUs
Ghilbi
New HBM AMD GPUs
Post by Ghilbi » 31 May 2015, 01:34
http://wccftech.com/amd-20nm-r9-390x-fe ... han-gddr5/
Guess that means a few less ms input lag with the new memory type?
Q83Ia7ta
Re: New HBM AMD GPUs
Post by Q83Ia7ta » 31 May 2015, 09:30
no
Sparky
Post by Sparky » 31 May 2015, 09:53
No, it would only be correlated to input latency by GPU render times.
lexlazootin
Post by lexlazootin » 31 May 2015, 12:28
Sparky wrote:No, it would only be correlated to input latency by GPU render times.
lol
Ghilbi
Post by Ghilbi » 04 Jun 2015, 16:54
Sparky
Post by Sparky » 04 Jun 2015, 17:52
Memory access latency isn't the same thing as input latency. Reducing memory access latency might get you a higher framerate, but a higher framerate is the only way it's going to have any impact on input latency. If you just turn up the graphics settings and stay at the same framerate, you're not going to see a change in input latency just because the memory access latency is lower.
Take a look at the timescales involved. even "slow" ram is about 1 microsecond. Input latency in gaming is typically on the order of tens of milliseconds. Very fast games might get into single digit milliseconds with v-sync off.
Ghilbi
Post by Ghilbi » 04 Jun 2015, 20:28
I see. Essentially, more frames reduces the variable input latency. If my understanding is correct, comparing a 144Hz monitor at 144fps to 288FPS then the probability that you'll get a updated frame (0-3.47ms max instead of 0-6.94ms) during the next monitor refresh increases? I'm currently planning a low latency rig with a target 288FPS minimum, I prefer less input lag over visuals for the most part. Right now I'm still searching around for any articles or posts that can quantify a gain over an alternative.
For starters, Gsync or Freesync? http://www.displaylag.com/reduce-input- ... ive-guide/ - seems to suggest 1ms gains over Freesync, though the test method is 60Hz so it's within the margin for error. Then there's this quote (http://www.expertreviews.co.uk/accessor ... ptive-sync):
One clear difference between Nvidia G-Sync and AMD FreeSync is how they handle graphics cards that produce higher frame rates than a monitor can handle. G-Sync locks frame rates to the upper limit of the monitor while FreeSync (with in-game Vsync turned off) will allow the graphics card to produce a higher frame rate. This introduces tearing, but also means that input lag is at an absolute minimum, which is important for twitch gamers such as those who play FPS titles.
There there's the 240Hz max over Freesync vs Gsync's max 144Hz - seems like a clear winner. I did come across: http://www.pcper.com/reviews/Displays/A ... -FreeSync- - not sure what all the overdrive/vrr talk is about in the comments?
Then there's picking a monitor; 144Hz, 1MS GtG, 1080p or greater is a good start but it's hard to find a pick when your scrutinizing every millisecond. http://www.displaylag.com/display-database/ - so far I've been going by these values divided by 2 (to offset the 60Hz testing method) and http://www.tftcentral.co.uk/reviews/acer_xb270hu.htm - Seems their method is slightly more accurate. Trying to keep the price around $500 or I'd grab that Acer model. http://www.overclock.net/t/1558635/vari ... -by-nixeus - holding out for reviews on this guy for now.
I've been looking into BIOS and software tweaks as well, https://forums.daybreakgames.com/ps2/in ... ive.69391/ - is this something applicable today? Then there's the almighty roach thread: http://www.overclock.net/t/1433882/gami ... ardware/10 - HPET disabled seems the most talked about tweak but I've read about varying results. Lastly, there's the older http://forums.steampowered.com/forums/s ... ?t=1315790 with a similar aim. No actual testing is cited (or remains buried in 150 pages).
Sparky
Post by Sparky » 04 Jun 2015, 23:44
Ghilbi wrote:I see. Essentially, more frames reduces the variable input latency. If my understanding is correct, comparing a 144Hz monitor at 144fps to 288FPS then the probability that you'll get a updated frame (0-3.47ms max instead of 0-6.94ms) during the next monitor refresh increases?
Not quite. 288fps on a 144hz display would imply v-sync off, which means your graphics card flips the new frame forward right in the middle of a refresh, causing a tear. If you're using v-sync, there would be a significant increase in latency when you become limited by the refresh rate, due to frames piling up in the render pipeline.
For minimizing input lag you have two good options: V-sync off at very high framerates(well above refresh rate), or VRR(g-sync or freesync) with your framerate capped in-game to just below your monitor's maximum refresh rate.
g-sync works better right now, but freesync is fine if you always stay within the monitor's VRR window, and don't care too much about ghosting(there should be a factory firmware update for some of the freesync monitors to fix the ghosting issue, but I haven't seen an updated review of it) Freesync is much worse if you go below the VRR window, as it doesn't do window shifting to keep displaying frames on time. There is currently no freesync monitor with a 240hz refresh rate, nor any announcements on plans to produce one.
The bios tweaks that can matter are generally just the power saving stuff and overclocking, a lot of the stuff you'll see people talking about is placebo. For input latency, the location of your bottleneck matters far more than anything else. You want to stay CPU bottlenecked, as that allows all the downstream pipeline stages to finish working on a frame before receiving the next one. Check out the gedosato thread and flood's input lag testing thread for more info on that.
flood
Post by flood » 05 Jun 2015, 13:13
all else being equal average input lag goes like
vsync off at high framerate < vsync off capped framerate = gsync capped framerate
Ghilbi
Post by Ghilbi » 06 Jun 2015, 03:29
Any word on nvidia or amd creating a predictive frame rate option? Would it be possible for to create a GeDoSaTo-like program for gsync/freesync?
AMD superiority confirmed (http://www.tftcentral.co.uk/articles/va ... efresh.htm): Image
Much gain, very objective.
Also, posted 2 days ago: http://www.anandtech.com/show/9337/amd- ... putex-2015
Update: We also have confirmation that the NX-VUE24 supports pixel overdrive
TN panel, overdrive - looking promising. Not sure if I'll go with 1 of the newsyncs to put savings into the gpu but having the option would be a plus.
