Someone knows if G-SYNC will work on the 880m?
Should work, it is a Kepler base GPU
I can't find information about, why does not work and if will ever work!
My system is a GTX 880m with MiniDP 1.2 output and the GPU is Connected with the MiniDP (I don't have optimus on my laptop because of a 120hz display)
I want to use the G-SYNC on a external Display
Does G-SYNC will work on the 880m? Or 8xxm 7xxm?
ToRaHh
Re: Does G-SYNC will work on the 880m? Or 8xxm 7xxm?
Just to let you guys know.
My G-SYNC monitor arrived and the G-SYNC works, I tested the pendulum Demo, and my nvidia control panel has new tabs for G-Sync configuration
