Post
by rijst » 08 Aug 2015, 07:36
I also had this once... do not recall how i fixed this...
But try this:
1. make sure no screens are cloned or extended in the driver.
2. only hook up your PG278Q so no other DVI or HDMI screens or AV amplifiers are connected to your NVIDIA graphics card and do a system stop/start (Note that a reboot is sometimes not enough to 'reset' the NVIDIA driver: system stop / start is needed.)
There are 2 options were to change your resolution in your nvidia control panel:
Under display:
1. Change resolution
2. Adjust desktop size and position
I facepalmed once, that I did not notice the other option.
Also a clean install sometimes also does not work as expected. Go in safe mode with network functionality, unstall the nvidia driver completely, remove C:\NIVDIA downloaded folders. Then redownload & reinstall the driver. This was advised a while back by NVIDIA support when I noticed this dependency in the driver: 340.52 had the 120Hz issue, and 337.88 did not. It did not solve my issue at the time though, so I kept running on 337.88 for a while.
I am currently running 350.12 without any issues.
If 'Change resolution' or 'Adjust desktop size and position' are not listing 144Hz (even in non standard modes) than either the driver is not installed correctly, or the EDID of the monitor is somehow broken/corrupt (if you were never able to run at 144Hz).
To check the driver, go to device manager, Monitors > If you have one screen hooked up, only one should be listed. By right clicking on that one you could update the driver... that is if you have a good .inf file of the monitor. I have never tried this on a gysnc monitor before so I advise to contact Asus support to create an inf file based on the EDID of the PG278Q.
By the way, at 144Hz my PG278Q is experiencing some input lag (I also read this in other places), this seriously messes with my aim in CS:GO. If you play FPS games, ...or others ... enable gsync and cap your fps_max at 125 for the best results.
