How can you set a Rog Swift to 75hz???
Grubbernaught
Re: How can you set a Rog Swift to 75hz???
Post by Grubbernaught » 07 Jan 2016, 10:44
Thought I would chime in as I am in exactly the same boat.
The workarounds listed unfortunately do not work in this instance as the new .8 runtime for the rift forces it to run in direct mode at the primary monitors refresh.
Thus us swift owners are bang out of luck as we cant run the primary in 75hz, so no rift at ideal refresh.
I have created a dual boot with win8.1 and run the old 5.0.2 runtime for elite dangerous and pretty much everything else rifty.
I REALLY hope they fix this for release as it is a pretty major flaw.
