Is it possible to get a decent 144Hz screen? (QC?)
Q83Ia7ta
Re: Is it possible to get a decent 144Hz screen? (QC?)
Post by Q83Ia7ta » 08 Mar 2016, 14:12
nightmaster47 wrote:While this new fancy (crappy) 144Hz all have color shift even if you looking directly in the center of the screen.
nightmaster47 wrote:Image
Center of the screen...just look at angle
f*cking clown
Dimaslg
Post by Dimaslg » 08 Mar 2016, 20:26
Got my Asus MG279Q today and I think I will return it and get a new one... :(
nightmaster47
Post by nightmaster47 » 09 Mar 2016, 03:39
Dimaslg wrote:Image
What if another one would be the same? Or worse?
IMO the only option is to get a dual monitors setup: one GAYming, one normal.
f*cking clown
STFU, center or not, this Dell is sh1t.
Falkentyne
Post by Falkentyne » 09 Mar 2016, 19:43
You STFU and go build your own monitor.
Go buy Toshiba or something or stick with your CRT. Cya.
nightmaster47
Post by nightmaster47 » 10 Mar 2016, 04:09
Falkentyne wrote:You STFU and go build your own monitor.
Imbecile, all TNs are bad. And your XL2720Z too. Also it's terrible w/o this idiotic firmware bug. And you are an idiot because you are buying a monitor to exploit a bug LOL. Sh1teater.
aeliusg
Post by aeliusg » 10 Mar 2016, 14:00
Oh, come on. You're the one who's buying TN after TN with expectations that are completely out of touch with reality. And you're back to square one. What a waste.
spacediver
Post by spacediver » 10 Mar 2016, 18:41
tempted to moderate, but it's rather entertaining seeing this fool rage.
Dimaslg
Post by Dimaslg » 11 Mar 2016, 09:49
Just ordered a replacement, dont know why if I leave a website or something opened for a long time (10minutes or so) it left like a residual image on the panel :s
http://imgur.com/a/vRkgX
http://imgur.com/a/tCQzd
Also the backlight bleed got better with it use, but still noticiable at watching movies or something dark.
click4dylan
Post by click4dylan » 28 Mar 2016, 00:52
The answer is Acer. here's the XB240H ABPR. best of all? it overclocks to 198hz at 800x600 or 193 hz at 1024x768. and it has GSYNC
