ASUS VG248QE - Realtime Scaling or Frame Buffered Scaling?
sfektsz
Post by sfektsz » 23 Feb 2016, 19:14
In the past I've experienced screen tearing when using Display Scaling in CS:GO (I play on 1920x1080), and switching to GPU Scaling fixed this, as for a few other people that had the same issue. Ultimately, I was trying to determine whether Display Scaling or GPU Scaling would be best for performance. I've tried to Google this, but I couldn't find any answers: Does the ASUS VG248QE (144Hz) use Real Time Scaling or Frame-Buffered Scaling
Also, when benchmarking in CS:GO (using the timedemo method), GPU Scaling does yield higher/more stable results, but I'm not sure how much that means.
lexlazootin
Re: ASUS VG248QE - Realtime Scaling or Frame Buffered Scalin
Post by lexlazootin » 24 Feb 2016, 03:22
Screen tearing all ways happens unless you enable v-sync.
>I was trying to determine whether Display Scaling or GPU Scaling would be best for performance. Also, when benchmarking in CS:GO (using the timedemo method), GPU Scaling does yield higher/more stable results, but I'm not sure how much that means.
Use GPU Scaling then, the more performance the better!
I'm not sure about your monitor in particular but if you're using 1080p just use the GPU scaling. it's sub 1ms lag.
Q83Ia7ta
Post by Q83Ia7ta » 24 Feb 2016, 13:16
lexlazootin wrote:>I'm not sure about your monitor in particular but if you're using 1080p just use the GPU scaling. it's sub 1ms lag.
By 1080p do u mean 1920x1080 or 1080 pixels height resolution?
lexlazootin
Post by lexlazootin » 24 Feb 2016, 21:03
Q83Ia7ta wrote:By 1080p do u mean 1920x1080 or 1080 pixels height resolution?
I mean 1920x1080, i don't even know if the scaler is even active or what not when using that resolution, so i would just leave GPU scaling on by default because i know it doesn't add lag (much lag <1ms)
Q83Ia7ta
Post by Q83Ia7ta » 25 Feb 2016, 02:29
lexlazootin wrote:I mean 1920x1080, i don't even know if the scaler is even active or what not when using that resolution, so i would just leave GPU scaling on by default because i know it doesn't add lag (much lag <1ms)
Hmmm. Sounds like at 1:1 resolution (native monitor resolution) videocard can use display or GPU scaling but I don't see any point to do it.
lexlazootin
Post by lexlazootin » 25 Feb 2016, 07:26
Q83Ia7ta wrote:Hmmm. Sounds like at 1:1 resolution (native monitor resolution) videocard can use display or GPU scaling but I don't see any point to do it.
Yea, but in the driver you have too choose one or the other, there is no "off" setting. And you might be right saying that it doesn't matter since it's native monitor resolution but since i know the GPU scaling is pretty much near perfect it would be safer to use that.
sfektsz
Post by sfektsz » 21 Mar 2016, 09:04
I've seen a good amount of forum posts discussing older NVIDIA Drivers, saying to use 'No Scaling' & 'Override the Scaling Mode Set By Games and Programs', as if that combination completely turns off scaling completely. I think it was late 200/early 300 series NVIDIA Drivers that they were referring to using.
