Settings on ASUS VG278HE
MaFIa
Post by MaFIa » 23 Jan 2014, 12:23
Hello
I will get my new monitor tomorrow ASUS VG278HE
I understand there is a difference if the light boost is on or off
How should settings be, and why has it not always to be active?
Thx
Re: Settings on ASUS VG278HE
Post by Chief Blur Buster » 23 Jan 2014, 13:25
MaFIa wrote:Hello
Thx
Some questions and answers are found in the LightBoost HOWTO and the LightBoost FAQ.
LightBoost elimination of motion blur gives you much clearer motion during triple-digit frame rates during panning/strafing/turning, which benefits fast-paced gaming such as FPS and racing.
LightBoost pros: Elimination of motion blur
LightBoost cons: Darker image, colors can be affected, flicker
You will want to test http://www.testufo.com/photo while turning ON/OFF LightBoost via ToastyX Strobelight. The utility makes it easy to turn ON/OFF via a hotkey or via mouse click. You can keep it on 24/7 if you don't mind the cons. I actually keep it on 24/7 as a preference. Others like to turn it off when exiting a game.
MaFIa
Post by MaFIa » 23 Jan 2014, 14:09
Dammm it is great with such a quick response to questions I have.
1000 thanks for this and the help
