i have gtx 1060 so i want 1080p 60hz monitor
i want it to have low input lag
so does BenQ rl2455hm have low input lag and is it good for PC or it is only for consoles
is BenQ rl2455hm has low input lag?
- lexlazootin
Re: is BenQ rl2455hm has low input lag?
It's hard to tell because monitors change by monitor to monitor bases, but going off their other monitors i would say yes, it's pretty low.
It might be better to get a second hand 144hz monitor or something.
abdoo59
i mean during BF or COD when i move the mouse will the screen move at the same time?
- lexlazootin
Well yea, sort of. You are kinda limited by 60hz.
But yea it will do you good.
