Presenting the ZOWIE XL2540 240Hz
Re: Presenting the ZOWIE XL2540 240Hz
Thank you!
I'm not so impressed by your photos and mine also. I hope it's just bad made photos.
mine results with Asus PG248Q @ 170Hz.
http://i.imgur.com/HzgnQfg.jpg
Is there any blur reduction options at OSD (BenQ Blur Reduction or Dynamic Accuracy) or no any at all?
Which AMA options are available?
Photos are as accurate as I could get them without having the Chief's pursuit cam setup =P
No motion blur reduction what so ever on the XL2540. AMA options are off, high and premium. They act exactly the same as previous models.
In contrast, the XL2735 has Dynamic Accuracy that is permanently on.
Falkentyne
You can turn off Dynamic Accuracy. It's just benq blur reduction renamed.
It's in the Service Menu.
the one thing sorely missing on the XL2735 is the "Single Strobe" setting for refresh rates lower than 100hz.
Awesome. Had a quick look through the settings and didn't see an option to turn it off. Will do a service menu check over the weekend when we do the full comparison.Falkentyne wrote:You can turn off Dynamic Accuracy. It's just benq blur reduction renamed.
Still love my XL2420G for the single strobe. Will ask the Zowie rep directly if single strobe is something that can be added.
Falkentyne
You have contact with him?
How can I contact him?
I have a way to flash the monitor if they will simply release the firmware but I need a way to contact someone at Benq / Zowie who actually will listen and care.
It's a contact for my work. Marketing. I'll press the issue but in the end marketing teams can only get so farFalkentyne wrote:You have contact with him?
- lexlazootin
Did you get a sample from Mwave in Sydney or did they send it to you? Are they only samples or retail units?
I'm impressed Australia got anything at all and kinda jealous.
Yeh the site I write for is owned by Mwave. Mwave partnered with Zowie at PAX Aus so I jokingly asked the lead editor to request a review sample of the new 240Hz monitor. Got a straight yes and never questioned it afterward.lexlazootin wrote:Did you get a sample from Mwave in Sydney or did they send it to you? Are they only samples or retail units?
Ehi, i have a question.Denonic wrote:Anybody have any questions about it?
Are the 240 hz really native? Or does the monitor use gpu scaling to achieve 240 hz? For instance every 144 hz benq monitor is a 120 hz panel that can reach 144 hz if using gpu scaling (with nvidia graphic cards, dont know with ati). If you are using windows 7, the easiest way to check that is to set the monitor to 240 hz and then check if you can use the display scaling features. So if you can select those options
while using 240 hz, it means the 240 are really native, if they are all blacked out it means you are using gpu scaling.
If you are using 8/8.1/10 i dont know how to check that, since the display scaling should be gone and you should use cru
I already asked benq if the monitor is really 240 hz and if you can use the scaling options while using 240 hz and they told me yes. But a double-check before spending 500€ is always good
Gonna wait for a 240Hz monitor with blur reduction option
I can live with 1 additional frame of input lag. At 240Hz it's only about 4ms of additional input lag. IMHO the benefit of having much less blur will greatly outweight the slight increase in input lag, at least in games when you have to make swift camera rotation.
