Firmware upgrade using Linux tool, requires no hardware
Re: Firmware upgrade using Linux tool, requires no hardware
just to clear up what im doing.
are these 2 commands ?
sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-6:49 (dump current firmware)
sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-6:49 -c "MX25L1605A/MX25L1606E" -r backup.bin.
backup.bin gets dumped in folder called flashrom. (which i will have to find on the OS)
place v5 firmware in a folder called flashrom and change the name to "XL2720Z_V5.BIN"
then run these 2 commands
tr '\000' '\377' < /dev/zero | dd of=firmware.bin bs=1k count=2k
dd if=XL2720Z_V5.BIN of=firmware.bin conv=notrunc
once completed, file is replaced to "firmware.bin" which was previously "XL2720Z_V5.BIN"
Now file is ready to be written to monitor
sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-1:49 -c "MX25L1605A/MX25L1606E" -w firmware.bin
This command
is what backs up the existing firmware into the name backup.bin. It's one command, not two.
the rest merges the 800k firmware you downloaded into a 2 mb file (by extending it with a dummy file that is created) and then flashes it. If you already have an existing 2mb backup (e.g. if you downloaded it from someone else's backup and its already 2 MB), you would skip the "dummy file" and "merge" steps.
Mine shipped with v4, im upgrading to v5.
At first the whole process looked complicated, but once i just started experimenting it made more sense,
I have never used linux,
I just wanted to make sure that the last bit i understood correctly, which i do. Now i can help a friend over the net to upgrade his v1 to v5 for all the added extras, including single strobe.
here is the ouput i got just before i need to dump firmware
Calibrating delay loop... OK.
Info: Will try to use device /dev/i2c-1 and address 0x49.
Info: WILL reset the device at the end.
Found Macronix flash chip "MX25L1605" (2048 kB, SPI) on mstarddc_spi.
Found Macronix flash chip "MX25L1605A/MX25L1606E" (2048 kB, SPI) on mstarddc_spi.
Found Macronix flash chip "MX25L1605D/MX25L1608D/MX25L1673E" (2048 kB, SPI) on mstarddc_spi.
Multiple flash chip definitions match the detected chip(s): "MX25L1605", "MX25L1605A/MX25L1606E", "MX25L1605D/MX25L1608D/MX25L1673E"
anyone know what code to use next
sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-1:49 -c "MX25L1605A/MX25L1606E" -r backup.bin
or
sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-1:49 -c "MX25L1605" -r backup.bin
or
sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-1:49 -c "MX25L1605D/MX25L1608D/MX25L1673E" -r backup.bin
or any other combination.
or
or
ok done
its just saying reading flash. waiting game now
how did you know it was that one? current firmware is now dumped. Now feel confident to flash v5. also confident to help a friend who is stuck on v1.
All of the monitors have the exact same chip. I wrote the instructions earlier remember? (but I was not the original writer; Bishi was (IIRC)).
The Mstar ISP device identifies the chip as the MX25L1606E. The RT809F also identifies the flash chip.
Remember if you want a less intensive AMA setting, when blur reduction is enabled, enable blur reduction and then set AMA to high afterwards (or just highlight high and press back). You can see the change in overdrive here.
http://www.testufo.com/#test=photo&phot ... &height=-1
It's POSSIBLE to reduce the overdrive for blur reduction DISABLED as well but this requires exploiting a firmware bug. In order to do this, you do the above (with blur reduction enabled), THEN You switch into a PICTURE ADVANCED Picture Mode preset that has blur reduction disabled in the preset. Disabling blur reduction directly won't work.
This is how you can get 144hz to look if you exploit this bug (blur reduction off):
thanks for clearing that up.
Hi there!
I created an account on this forum just to thanks everyone involved in this firmware upgrade method. I just successfully upgraded my XL2720Z to V5!
After massive DisplayPort issues (blacks flickering, signal loss and ludicrous resolution/framerate), I first tried a certified DP cable but it didn't help. More googling later, I ended up on this board and understood that my monitor was on V3, and needed at least V4 to fix those DP issues.
I followed the tutorial as stated earlier on this topic, but I'm gonna log some steps that were completely different for me, for others people who will do it after me:
This first attempt was using a DVI to VGA adapter and a VGA cable. The monitor power led was RED, screen was black but still detected in ubuntu settings as well as in the terminal on bus 4. After reading (and sweating a bit as well
), I redid the flash but only with a DVI cable (so no VGA whatsoever), and 20 minutes later, it works! \o/
No DP issues, I can turn on/off my monitor as I'm typing those lines. It just works!
So yeah, thanks again!
- Updated with a CLEVO P150EM + GTX 675M, no VGA port available but DVI did the trick
- The monitor wasn't on bus 1 but on bus 4. e.i. I could only see the monitor model with "sudo i2cdump -r 0-127 4 0x50" instead of "sudo i2cdump -r 0-127 1 0x50". This means that every single command (dump, flash, etc) to the monitor had to be rewritten with 4 instead of 1. I thought I'd mention that since it wasn't well documented as far as I found on the topic.
- My flash ship was "W25Q16.Q", not "MX25L1605A/MX25L1606E". So same with the bus, I had to make sure the correct name was written.
Code: Select all
Verifying flash... FAILED at 0x00000000! Expected=0x02, Found=0xb0, failed byte count from 0x00000000-0x001fffff: 0xfe
