Blur Busters Forums
Presenting the ZOWIE XL2540 240Hz
Re: Presenting the ZOWIE XL2540 240Hz
Postby Comanglia » 18 Mar 2017, 11:00
Just wanted to add to this that saved setting include the Blur Reduction. So if you have Gamer 1 saved with blur reduction and gamer 2 with none Gamer 1 will turn blur reduction back on. Probably not surprising for most, but wanted to make sure everyone knew about this.
Comanglia
Postby b0t » 19 Mar 2017, 03:35
Chief Blur Buster wrote:
RealNC wrote:I also would assume the blur reduction works best at 120Hz?
BR is available at all refresh rates on the XL2540, however, there's some users who report Blur Reduction (with certain adjustments in Service Menu) looks best at approximately ~180Hz and under. This is normal, as Blur Reduction needs a refresh safety margin (to allow LCD GtG to settle in darkness between strobe backlight flashes).
Or if you prefer to avoid strobing, there is noticeably less motion blur and mouse droppings (phantom array effect during fixated gaze) at 240Hz than 120Hz.
What do u mean by mouse droppings?
Btw what settings do u guys use on this monitor.. Both BR off and on.. (Blur reduction ON 240hz is not the best for me)
Also.. Whats the highest VT value that can be set with 180HZ?
b0t
Postby bennzl » 19 Mar 2017, 23:55
I'm currently using 180.745Hz with a VT of 1595
bennzl
Postby b0t » 20 Mar 2017, 00:06
bennzl wrote:I'm currently using 180.745Hz with a VT of 1595
Why not just 180? Why the .745?
b0t
Postby bennzl » 20 Mar 2017, 06:15
I found that I couldn't use a VT as high when using 180. I'm not sure why.
bennzl
Postby b0t » 20 Mar 2017, 09:14
Highest @ 180? Like 1590 or less?
b0t
Postby bennzl » 20 Mar 2017, 16:11
Highest at 180Hz I could get was 1570.
bennzl
Postby Silent Raider » 20 Mar 2017, 19:07
To play FPS I'm using:
BR on
182.000Hz
VT 1584
Intensity 12
Area 12
Contrast 35
Silent Raider
Postby Falkentyne » 20 Mar 2017, 20:48
Guys, I need to confirm please:
Adaptive sync (Freesync) only works on this monitor if you MANUALLY edit in the freesync range in ToastyX CRU (48hz-144hz or something) in the extension block, and then have blur reduction off in the service menu?
Can you guys please confirm?
Falkentyne
Postby b0t » 21 Mar 2017, 04:26
Highest at 180Hz I could get was 1570.[/quote]
Thank you:)
Silent Raider wrote:To play FPS I'm using:
BR on
182.000Hz
VT 1584
Intensity 12
Area 12
Contrast 35
Ty very much for sharing your settings.. Will try it as soon as I get home
b0t
PreviousNext
Who is online
Users browsing this forum: Google [Bot] and 14 guests
