Questions about new G-Sync monitor
Post by jorimt » 30 Jun 2017, 17:21
No parini, if I understand you right, G-SYNC + V-SYNC "Off" will not fix the stutter.
I need more details to help you:
-What game?
-What game settings?
-What G-SYNC settings?
-How much stutter
-How long is stutter
-When does stutter happen?
parini
Post by parini » 30 Jun 2017, 17:24
I'm now with vsync in 3d appication and stopped stuttering, gsync works that way I'm with fps also limited to 162, does gsync work the vertical sync in use the 3d application setting?
Post by jorimt » 30 Jun 2017, 17:26
parini, you want G-SYNC enabled and V-SYNC enabled in the Nvidia Control Panel. You also want an 162 FPS limit set either in the game or RTSS.
Are you saying the only way the stutter stops is if you enabled V-SYNC in the game? Is that game League of Legends?
parini
Post by parini » 30 Jun 2017, 17:28
I deactivated the vertical sync on the panel in both is not enabled I just left the gsync enabled along with fps limiter and the stutter stopped and I am not having image break.
Post by jorimt » 30 Jun 2017, 17:30
parini, some games like League of Legends may not work with Nvidia Control Panel V-SYNC, and you'll have to use the game V-SYNC instead with G-SYNC enabled.
parini
Post by parini » 30 Jun 2017, 17:35
One question is it possible to use gsync only by limiting fps without having to use vsync?
Post by jorimt » 30 Jun 2017, 17:41
parini, you can, but it will still tear sometimes, even with a framerate limit.
Remember, V-SYNC with G-SYNC enabled is not normal V-SYNC. It is just a function of G-SYNC to prevent tearing at all times.
parini
Post by parini » 30 Jun 2017, 18:31
For me to be able to play 1080p with gsync do I have to only put the resolution of the game in 1080p or the desktop?
Post by jorimt » 30 Jun 2017, 19:22
Either, parini. Changing resolution in the game is easier though.
parini
Post by parini » 30 Jun 2017, 19:24
How do I get rid of my cage and at the same time amuse myself with gsync?
