Blur Busters Forums
G-Sync and ULMB at the same time is in fact possible!
Re: G-Sync and ULMB at the same time is in fact possible!
Postby Chief Blur Buster » 10 Apr 2018, 14:42
Thats OK!
I also now have an XB252Q in my possession so I am able to do ULMB+GSYNC too, I had known...
But it is always good to hear user success reports!
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Postby Zazie » 11 Apr 2018, 14:26
Chief Blur Buster wrote:Yes, the ULMB+GSYNC trick should work with that.
Remember, the combined ULMB+GSYNC trick works best only over a tight framerate fluctuation range (e.g. 75Hz-120Hz, or 75Hz-144Hz).
Which technique should I use?
Zazie
Postby KindOldRaven » 11 Apr 2018, 16:22
Chief Blur Buster wrote:Thats OK!
Got a bit overenthusiastic there haha :lol: Had any chance to play around with the XB2 so far? I'm curious to see how others feel about it, since most people seem to go for the ASUS version of this panel or the Alienware one. (After having used all its features in-game my only gripes with it are getting used to gammashift again after the CFG73 and the fact that 240hz on 'normal' OD causes some overdrive artifacts when browsing (scrolling -red) on some website with particular color transitions, including this forum when middle-mouse button scrolling I can see 'white ghosting' (or deep orange in the quote boxes if contrast >>40) behind the black text quite clearly despite 20 brightness, 40 contrast etc. But I'm quite picky.)
On-topic:
I'm trying to mess around with the most stable FPS-cap I can find (RTSS so far) combined with setting High Performance windows mode (stabilizes framerate caps for some reason... learnt that from Battle(non)sense on YouTube) for erhh... SyncStrobe (GStrobe? G-ULMB?) mode.
What do you guys use it for mostly at the moment? I've used it as an easy (but flickery) 60-85hz strobing mode mostly so far and it takes some getting used to but man... This is quite something.
KindOldRaven
Postby lexlazootin » 11 Apr 2018, 22:08
The main fault is that you need a pretty stable fps or else you're going to have problem. I wish i could have it so ULMB will turn off if it drops below 90 fps.
I haven't really tried with Emulators but i bet it would be super dope :P
lexlazootin
Postby Chief Blur Buster » 12 Apr 2018, 16:17
I think ULMB 60 Hz is more ideal for emulators than the ULMB+GSYNC hack, unless the emulator framepacing is nearly microsecond-accurate.
Also, I'm corresponding with a few emulator authors to add beam-racing capability (sync between emulator raster & realworld raster), via a new unique lagless VSYNC ON mode a small group of us has successfully come up with (beam-raced tearingless VSYNC OFF)
Postby mds83 » 20 Apr 2018, 09:25
I see people talk about using only 120hz or 144hz for this hack.
But what about 100 or 85hz? Are their any cons to that? Besides the flicker.
BTW: I have the Dell S2417DG and the +5 VT doesn't work for me anymore (ulmb gets greyed out in the osd). It did a year ago which is odd.
mds83
Postby RealNC » 20 Apr 2018, 09:32
mds83 wrote:I see people talk about using only 120hz or 144hz for this hack.
If g-sync becomes active, the refresh rate is controlled by the frame rate (which is the whole point.) So in 120Hz mode, an FPS cap of 100FPS will give you 100Hz.
Postby Vipu » 06 May 2018, 19:19
I got ViewSonic XG2703-GS and I totally forgot about this g-sync + ulmb thing and really want to try it.
Not wanting to scroll thru whole thread, is there some ready settings that someone have found that I could just copy?
Or some easy steps what to do to do it myself.
Vipu
Postby RealNC » 06 May 2018, 19:29
Vipu wrote:I got ViewSonic XG2703-GS and I totally forgot about this g-sync + ulmb thing and really want to try it.
viewtopic.php?f=4&t=2883&start=180#p25651
Postby Vipu » 07 May 2018, 04:01
I followed those steps but cant get it to work, without CRU.
Vipu
PreviousNext
Return to Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
Who is online
Users browsing this forum: No registered users and 8 guests
